Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanner failure The printer just stopped printing and the screen reads 'scanner failure' Then I put it off and on and press enter to re-align cartridges and then it makes a noiuse and says 'scanner failure' again
  • 2 more comments
  • sales663 Dec 05, 2008
    that does not work. How do i disconnect the scanner so that i can print only
  • Anonymous Mar 25, 2009
    while copying i hear a ripping sound, the display reads scanner failure can't copy scan or print. turn off and on and try again
  • Anonymous May 14, 2009
    I have the same issue and the solution did not work - any other suggestions?
  • dukuray6 May 15, 2009
    i have the same problem nd it didnt work
    Scholar:
  • 105 Answers
This is a serious hardware issue where you will not be able to copy or scan from the printer. However, printing is still possible. The only possible steps for this issue are Connecting it to a wall outlet directly, and performing a semi full reset..
Disconnect the power cord from the product.
Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
After performing this step, try making a copy. If the issue does not resolve, replacing is the only option available.
Posted on Dec 04, 2008
  • 20 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
a17
Posted on May 28, 2009
The screen says, "press enter to align your cartridges" !!!
The alignment process prints one page, and then you put that page into the scanner. The scanner reads the page, compares the actual alignment with the optimal alignment, and adjusts the printer, in order to produce "sharp" (opposed to "fuzzy") colour pictures.
Aug 22, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Changed cartridges, printer doesn't align or function
Something seems to be physically wrong in the mechanism.
Try the rolling wheels and the belt on which the cartridges run.
Jul 19, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Won't print. Screen keeps saying to press Enter to align cartridges but nothing happens
It is the test page it is alignment test page just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
Have a nice day and do not forget to rate please...!
Mar 17, 2010 | HP PSC 2175 All-In-One InkJet Printer
HP 2210, screen says to press enter to aling cartridges
Once you replace a cartridge on a 2210 ya page prints and you must put that page on the scanner window and then press enter. Your computer will go through a calibration to align the print head. once this is done you can throw away the paper and printing will be normal
May 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp 2210 all in one printer/scanner
after replacing the ink cartridge align the printer. Press alignment cartridge located in the printer properties. After printing the alignment get the paper and put it in the scanner. The computer reads it
May 04, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Align cartridges
Hi ,
can u cet alignment print from u r printer if u get this printer .
please put this print on scanner & press scann button for scanning ........it will automaticaly align u r cartridges & printer will get ready for printing ......
if this information is useful for u please Rate me...........
if any update give me comments for it....
thanks & regards
Sandipk
Jun 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Put in a new cartridge
i don't have driver
i want to load driver printer hp psc2210
Apr 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Align page message
I have an OfficeJet 5780 and I have to do the alignment also. The allignment page it prints should have instructions on it. Just put it in the scanner and press "Enter". It needs to scan it to align the print heads.
This is from the manual on their website:
The HP Officejet prompts you to align cartridges every time you install or
replace a print cartridge. Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1 Press Enter on the front panel.
An align cartridges (test pattern) page prints.
2 Load the align cartridges page face down in the ADF between the paperwidth
guides and press the Enter button again.
3 Recycle or discard the page.
Geno
Feb 21, 2008 | HP Officejet 4110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
159 people viewed this question
Seeker5211
Seeker5211
