Question about TruTech PLV16190 Television
Sap is on even though the menu says it's off - TruTech PLV16190 Television
    Scholar:
  • 73 Answers
I would first try unplugging the unit.
then look for a factory reset in the menu, if it has one.
these sets are notorious for problems, look here
http://www.iconnectdots.com/ctd/2007/05/targets_trutech.html
Posted on Jan 09, 2009
Turn off sap
SAP is secondary audio program---It can be turned off or on in a possible two places.
On the set in the audio menu (most original remotes have a SAP or MTS button for this but in the set menu it can also be adjusted on or off.
If you are using a cable or Sat box or even a receiver the box will have the SAME feature built into it--yes Sap can come from a cable box or sat or receiver.
May 24, 2012 | Sansui 32" TV
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
There is no sound from the unit. I have no remote but it says it is in sap mode. can I correct this?
SAP means "Separate Audio Program" - usually SAP mode is for changing the language of the broadcast (i.e. from English to Spanish) and is also used to enhance the sound broadcast of some programs.
Not having a remote may make this difficult.... you need to find a way into the set's menu- some sets have a "menu" button on them..... some require two buttons be held down together.... look at the set carefully.... if you have the manual, it is a good time to look at it.
When you get into the menu, find the AUDIO menu and de-select SAP. Your sound should be restored.
If you cannot get into the menu, you will need a remote. Write down the brand and model of your set, go to a decent electronics store, and browse the "universal remotes". Find one that supports your set and follow the instructions to set it up for your television. You will then be able to access the menu and turn off SAP.
Jan 28, 2011 | Televison & Video
Sap stuck on
It may be that you think you are moving it to off but not saving the changes.
These TVs are notorious for problems, look here.
Dec 03, 2008 | TruTech PLV16190 Television
I have no sound on channel 2. All other channels the sound works fine. There are no audio cables going to it. Just straight cable. Even moved it to another room to see it would make a difference. And it...
Hello mwrobinson19,
Check to see if SAP (Second Audio Program) is turned on. Having SAP on can often cause this problem. You will have to go to the audio settings from the menu and select to turn SAP off.
I hope this helps,
Thank you,
Shuttle83
Oct 09, 2008 | Norcent Technologies LT-2022 20 in....
Cant turn sap off missing sound on some channels
Hmmm, you'll need that original, there. See if you can find one, and maybe even just borrow one to get what you're after...accordianman
Feb 09, 2008 | Sharp 27H-S60 TV
Sansui DTV2760 27" TV
Since nothing else has worked, are you sure that the SAP function on the Cable Box is not turned on?
Sep 05, 2007 | Sansui DTV2760 27" TV
Sound isn't working correctly
Hello dotdeb99, Use your remote to go to the menu on your TV and scroll through the menu items, you should see the SAP feature. Then turn it off. You can also get the users manual for your TV on-line and it should have SAP instructions in it. Just remember SAP is a TV menu item, it will not be actually on the remote itself. Thank you.
Plasma tv with suspected SAP turned on
Hi
Try going to the audio menu then audio language and see what your settings are also try going to the options menu then caption/text and see what your settings are also in the options menu go to caption option. if that doesn't help try the same thing with the dvd player. hope this helps.
May 28, 2007 | LG 42PC5D Television
TruTech PLV16190 Television Logo
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
