Question about Coby MPC-848 MP3 Player
Azone MP3 Player 128M won't play
Came preloaded with information which I cannot access. Put in new battery but cannot access different "Modes" unit will turn itself off and will not play at all. Can you help me. We had a fire and I have lost instruction manual.
  • LOYAL2DEE Mar 24, 2009
    my azone mp3 player 128m wont play
  • Anonymous Mar 24, 2009
    I can't get it to play either.
5 Suggested Answers
SOURCE: Coby MP3 player doesnt work anymore
Don't EVER buy another Coby product.
I have bought (4) . . .   NEVER AGAIN ! ! !
Posted on Oct 14, 2007
SOURCE: Coby MP-C848 MP3 Player
how do i get music on to my coby mp3 from the computer, my daughters works from the computer why doesnt mine
Posted on Jan 08, 2008
  • 5 Answers
SOURCE: locked coby mp3 player without manual
There should be a lock/unlock button on the opposite side of your mp3 player other buttons. Slide the button to the left, and it should unlock. I hope this helps.
Posted on Jan 27, 2008
lucas zgoda
  • 89 Answers
SOURCE: my azone mp3 player says disk error
dude reformating the mp3 is realy easy just click with the rigth buttom of the mouse on the mp3 icon then click on the opition reformat
Posted on Jan 28, 2009
stonephoenix
  • 563 Answers
SOURCE: My new Coby MP3 player wont play my music.
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Your music may be in the wrong format or it may have DRM protection which is a license created by the recording industry. If you call our tech support number above, we can walk you through discovering why the music won't play.
Coby players can recognize .mp3 and .wma audio formats. If you're pulling the music from iTunes, it's in the wrong format and will not play on a Coby without being converted.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 06, 2009
Fill player files won't play. says i need firmware update.
in this case you should upgrade the firmware of your player. If you use this link you will get all information detailed how to make upgrade. The firmware file will be accessible also.
gylacz
Apr 04, 2012 | RCA Pearl TH1102 MP3 Player
How come when I plug my new mp3 player in my car, it only plays the preloaded songs that came with theproduct? I have an MP727-8G
you have to have the songs you loaded in the same root folder as those songs in order for the head unit to find them. Connect the player to your computer and open the files to view. Browse your way to the preloaded songs and simply move the others to that same folder. While your there, you may want to delete the preloaded stuff that you dont want.
GOOD LUCK AND PLS RATE THIS POST!!!!
Jun 06, 2010 | Creative Labs Zen V MP3 Player
Deleting music
There are two modes of use for your player. Once you put music or files on it in one mode you can tell files are there but you can not access them or delete them. So, You have to access the files on the player the way they where put on the player. The modes are Msc & Mtp to see more about this click this link ...Solve your MP3 Player Connection Problem.
May 29, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
ATMT MINI MP3 Player: my daughter has done something to her mp3 player a...
It's look like a memory issue. Try resetting the player. This can only by removing the battery for a minute and reinserting the battery. If this doesn't help, format the player if it's recognised by the computer and reload some sound tracks. Make sure there are different modes between" audio player" to synchronise music using windows media player and devices with removable storage where you can copy and paste music. I think this mode can be changed byu pressing the "M" button.
May 18, 2010 | Digital Mind Corporation ATMT MINI MP3...
Mp3 player
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)
Here's some general info about the problem: 1.      1.       “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE)
The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Many laptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button.  There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard.
Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue.
If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this.
Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.”
If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components.
If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Sep 06, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
The songs on my mp3 will not play. They appear on the screen but no sound. THere seems to be trouble with the battery.
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)  Here's some general info about the problem:  “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE) The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Manylaptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button. There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard. Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue. If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this. Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.” If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components. If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Jun 03, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Rca mp3 TH1012
have you tried another battery perhaps the battery is at fault
Mar 21, 2008 | RCA Lyra TH1012 MP3 Player
No instruction book and no music to be played
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Nov 13, 2007 | iLO (2 GB) MP3 Player
Coby MPC-848 MP3 Player Logo
906 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
