Dear Elvira, You have to disconnet your power supply from the mains by pulling out power cord then the open the side pan of your cabinet and locate the ram.remove the ram and resit it in another slot. then connect your power cord to the power supply of your pc then switch on. If the problem is not solved then again remove the power cord and remove the cmos battery from the motherboard and wait for 20 seconds,then put it back.and power on the system. if the problem is not solved then try with another powe supply.still problem is there then your motherboard may be bad.you have to replace the motherboard.
There's a little button on the front of your 360 and the same button is on the front of the controller. You hit the button on the 360 and the green lights around the power button start to circle. Then you hit it on your controller and the green lights around thexbox guide button start to circle. In a second or two they'll find each other and both will flash at the same time, and it's synced up. I think there's a little symbol of air waves next to the button. Try this it should fix your problem
The constant beep means that the channel you are on is not programmed. Try moving the channel knob to other channels. If it stops beeping, you are on a channel that is programmed. It is possible that none of the channels are programmed though.
Take it to a motorola dealer and they can program it for you.
make sure the top screen ribbon cable is attached to the connector properly, push the cable in as far as it will go and then try again, if that dosent work it may be a fuse on the board prob f2 if that dosent work change both it should fix the problem
Many problems with philips can be solved by doing a software update which is done with a flash drive in the USB port. The only problem is your model number dosen't show up on philips web site. You may want to try to email them from their site to ask why your's dosent exist.
