Question about Lexmark Office Equipment & Supplies
Printer is jam not feeding evenly;also one of small rollers is missing
    Problem Solver:
  • 10 Answers
If one roller is missing why bother asking for a solution to the problem?
The missing roller IS the problem...
Posted on Dec 03, 2008
Media missfeed
First what model? Second miss feed and jam are different, miss feed the roller can grab the paper, replace the roller putting a rubber sleave is going to mess with the feed system. Clean the rollers with alcohol
Apr 01, 2015 | Minolta Office Equipment & Supplies
Mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
Mar 04, 2012 | Canon PIXMA MP495 InkJet Printer
13.02.00 paper jam on tray 2. i have removed the tray and even the catridges but can't find any paper. I don't know where the sensor is as this may be the cause as well. Please need urgent...
Number 1 you failed to mention what kind of printer you have.
Number 2 when you print, does paper even feed into the printer?
When was the last time that you replaced the feed rollers?
Yes it is possible that a sensor is jammed. Before the 13.02 error,
did the printer actually have a paper jam? If yes, was there a piece of paper
missing from the jammed sheet or was it whole?
Jul 15, 2011 | Office Equipment & Supplies
When i click print the paper feeds fromright side and jams.
if your paper feed not straight, most probably the feed roller.. the roller which feed the paper is broken.. the normal broken area is the tip holding the roller, it can be repaired if you know how to open the printer and remove the roller.. you can always drill a small hole and insert a small round wood piece..
to be sure, try feeling the roller with your hand first.. if there is much free space between the roller and lower part.. then most probably it's broken..
May 23, 2010 | Canon PIXMA MP190 All-In-One InkJet...
After paper jam was cleared my printer wont feed
There is a small plastic gear that turns the roller, and when a paper jam occurs, oftentimes the gear strips it's teeth, and then the roller won't turn and feed the paper. I had this happen with an HP printer, and took it apart to see what the problem was. Upon finding the stripped gear, I tried to contact HP to get a replacement part and was told that they don't sell parts to anyone except HP authorized dealers, so I found a used printer and cannibalized the part, replacing it myself. Unfortunately, the broken gear problem happens a lot. About the only thing you can do is maybe load less paper, or load just the sheets you need for your print job, but even this doesn't guarantee that a jam won't occur. If you use labels a lot, they can leave glue residue on the rollers, causing a jam. You just have to keep them clean and hope for the best. In my opinion, the clean roller maintenance doesn't always work, and just a small amount of adhesive on the roller(s) can mess you up. They use a lot of plastic parts in printers these days, so they're very susceptible to breaking. Unfortunate, but that's the way it is. I guess that's their way of ensuring the printers won't last an awful long time, making people buy replacement printers sooner than they should have to. Don't think any one printer is necessarily better than the other, these days, so just try not to overload the paper and hope for the best. Sorry I don't have better news, and good luck.
Apr 06, 2010 | Canon MP490 InkJet Printer
Paper jams at every feed - even after I clear the jam...
Make sure all paper has been removed from the paper path.
Even a small scrap will cause a jam.
The other thing you may want to do is clean the paper rollers with alcohol.
This cleans any paper dust that has gathered on the rollers, and allows better paper movement.
Sep 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Epson Stylus C82 won't feed paper evenly, and only feeds on the right, resulting in bad paper jams. I've tried everything; is there a special cleaner that I can use on the rollers or ?
first, try turning the printer upside down and see if anything comes out. i have seen in the past kids puttnig things in there etc... and that solves the problem.
There is only 1 main pickup roller so I dont believe its that, you might also have a small piece of paper jammed in that area.
thanks adi
May 07, 2009 | Epson Office Equipment & Supplies
Paper jam indication, but cannot find the paper that is jammed
I would check to see if the paper is even making it out of the tray. A lot of times, the feed rollers can get dirty, and the printer will display a jam if it doesn't feed in time. If the feed rollers look ok, then I would check and see if the feed rollers are even turning. Sometimes the motor that turns the feed rollers wears out.
Nov 11, 2008 | Ricoh Aficio CL7200 Laser Printer
Error 391: paper jam
See below for Error 391:
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Apr 04, 2008 | OKI C5200n Laser Printer
Lexmark 1185 - paper feed problem
You may be missing a very small jam. Use a torch and tweezers, check down the back, also open cover, check even where you think paper wouldn't jam. Especially in teeth, rollers. Look for foreign debris as well as paper. Also, turn off, unlplug all cables/usb etc and replug, turn on. Finally, never load more than about 20 fine sheets at a time, reset printer settings to default. As a last resort, try uninstalling and reinstalling the printer.
Aug 25, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
