Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
Dyson dc14 has no suction and burning smell
How do i change belt
  • dange11009 Dec 24, 2008
    I cleaned out the bottom and now it won't work, the top still works??
The guide suggest that you change the belt by putting it around the brush, through the plate, and then try to push it around the spindle, which has a space between it and the casing. I spent an hour trying to do this and couldn't get enough purchase to get the belt around the spindle. Instead I put it around the spindle first, and then through the plate, and then through a screwdriver to hold it in place. I then got the brush and put the band over the brush, rotating it until it went into the groove. I then reassembled. It worked, and I now realise how powerful that brush is. Hope it works.
Posted on Jan 06, 2009
  • 107 Answers
You cannot change the belt you must change the whole clutch assembly. If you can get the part I will walk you through it over chat.
Posted on Dec 09, 2008
2 Suggested Answers
Samyfam
  • 379 Answers
SOURCE: My dyson dc14 has a strong burning smell
A DC 14 has two belts - one that connects the motor ourput to the clutch mechanism (the dial that lets you turn off the brush rotation completely is part of the clutch mechanism), and another that connects the clutch to the brush bar.
Unfortuneatley, the one that connects the motor to the clutch is hidden under a plastic cover so is very difficult to check.
With the machine running, and NOT in the upright position (i.e. as if you were vacuuming a floor), make sure the brush bar is actually rotating. If it isnt, you need to check both belts and the clutch. Due to the cover being held by three "Torx" screws, one of which is very difficult to get at, this isnt easy.
If the brush bar is rotating, then the burning is an indication the motor is about to fail. Motor replacement is possible depending how good your DIY skills are, and again you'll need "Torx" drivers to dismantle it. Website www.dysonmedic.com has some very good info.
Posted on Oct 10, 2009
When my dyson dc14 hoover is on it has a strange burning smell, and a noise like air popping, there seems to be suction from beater and it spins. and definitley suction from extension. Filters are clear...
It could be the belt. However, the popping sound does have me puzzled. The popping could be coming from a partially broken belt slapping against plastic.
Jim
Sep 09, 2010 | Vacuums
We have a DC14 burning smell then not working
i am afraid that is ur motor that has blown this can be easily repaired by dyson ring the no. on the vac full service and repair only £60
Mar 20, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Dyson makes smell
You need to replace the belts. When they are worn they put off a smell. Here is the belt you need:
Dyson DC14 Belt
Feb 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
On the DC14 the brush bar is not spinning. The belt is still attached and there is suction. Any ideas ?
Even though the belt is intact it can still be stretched and worn and that would cause the brush to not turn. Here is the belt you need:
Dyson DC14 Belt
Feb 09, 2010 | Dyson DC14 All floors Bagless Upright...
My dyson vacuum appears to still have suction but it doesnt
That means that the belt is stretched or worn. This causes the roller brush to not be able to turn the way its supposed to against the resistance of the carpet and therefore won't pick up well. You need to replace the belt. Here are the belts you need:
Dyson DC14 Belts
Feb 07, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Have Dyson DC14. Lots of suckion through hose but
Had the same problem on brand new cleaner DC14 and it was the belt that drives teh front roller not being connetted to the small silver motor spindle. I just opened the front roller cover (3 easy unlocking screws on base) and saw black rubber belt was not connetted and was loose. I just flipped the belt over the silver motor spindle and away we go (after cover was put back on). It now works as it should!
Feb 06, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
It wont vaccum
If the brush isn't turning you need to replace the belts. You can get replacement belts here:
Dyson DC14 Belts
Nov 21, 2009 | Dyson DC14 All floors Bagless Upright...
The brushes wont turn,but it has good suction for the hose
you have to remove the bottom cover to inspect the belt. Usually if the brush is jammed, you will smell an odor similar to burning rubber. In the absence of that smell, its likely the belt. Its easy to replace
Sep 20, 2009 | Dyson DC14 All floors Bagless Upright...
The brush on my dyson dc14 animal will not rotate
You probably have a broken belt. You need to take the plate off the bottom and see if the belt is broken. If so, contact Dyson (1-866-693-9766) to get another belt.
Mar 27, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
1,160 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
