Question about Dryers
Dryer timer last night i turned the dryer on before bed and when i woke up it was still on, but also it was still cold? is it the timer,or the element?
  • 76 Answers
Timer is gone sometimes cheaper to buy a new dryer
Posted on Dec 03, 2008
WED5321SQ0 dryer doesn't heat or shut off once it's running
well if ran all night you maybe be running a even heat or auto dry cycle. i would first try on a timed dry see if heat then. if does heat (which probably wont) you will be need to replace either the sensor or board that controls the auto dry. or a very small chance that the timers bad. most likely you have a bad heating element. if the machine doesnt heat on the timed dry, then you need to check continuity on the heat fuse(located on heat element housing). if good then check continuity on heat element. i would say you have a bad element or heat fuse.
Aug 01, 2010 | Whirlpool Dryers
It won't turn on. It worked last night and I plugged it in before I went to bed, and when I woke up it was black. It won't turn on now or make any type of sound.
battery could be gone..also you could check wire connections to battery. Even better measure if the battery has a charge with a voltmeter.
Jun 13, 2010 | Samsung Behold Cell Phone
Went to bed last night with heat woke up today everything house was cold, looked at thermastat it said 63degrees,, checked out furnace it starts up but doesnt ignite, sounds like its in the start up stage...
Does the hot surface igniter glow? If not, it is probably cracked. If this is
a 90% furnace, it could be that yuor intake air is causing the problem.
Dec 27, 2009 | Goodman GMS90703BXA Heater
Lost Power
Replace the thermal fuse inside the control panel.
Part #3376359
Mar 11, 2009 | Whirlpool DU960PW Dishwasher
Dryers Logo
50 people viewed this question
Top Dryers Experts
