Question about Dryers
Electric whirlpool dryer
My dryer squeaks when you start it and it sound like its the drum spinning? then it stops after 5 minutes?/ I tried to oil it ,but i am not sure where to do this?
    Sergeant:
    Champion:
  • 291 Answers
You need to replace your drum rollers and idler to fix the problem / if you need them let me know and i will see if i cant help you with info on parts / larry
Posted on Dec 05, 2008
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
Squeaking sound in dryer at the beginning of each drying cycle that for the most part goes away after 5-10 minutes.
you could have a rusted idler or drum roller. need to take dryer apart and look at them. use mineral oil or special bearing oil to lubricate it.
Feb 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LEW0050PQ electric dryer makes a noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
2 year old Kenmore Elite Front Load Dryer makes loud squeaking
We can fix this. your dryer has some wheels/rollers and an idler pulley they get worn and or plug up with fabric sheet guu.what you do is pop the top,that the frount off and this will expose the drum,undo the belt the clean inspect /oil and replace worn parts.sounds like you wont see much wear because it stops after[gets warm]so may get buy with oil/cleaning Ps unplug before working
Dec 31, 2008 | Kenmore Elite HE4 Electric Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
