Roller is broken. Need to find a replacement.
This is a link to Sears website. They have replacement parts for a ton of household items. If you look on your id plate on the vac post your exact model number here and I'll go look up the exact part, however, the one I found is in this link and it looks just like your vac. So This may already be the right one. and for 27 bucks it's not too bad. http://www.searspartsdirect.com/partsdirect/part-model/Eureka-Parts/All-Products-Parts/Model-4700A/1281/0645000/50031517/00001?blt=06&prst=&shdMod=4700A Hope this helps you
SOURCE: belt on motor roller
no only take the bottom off ,there will be three screws,take the belt put in over the shaft of the motor , loop it ,run it over the silver spindle to the brush assembly ,replace the brush in the slot that it came from,the belt now is over the motor shaft running over the spindle ,and over the brush assembly,replace the three screws and you should be good to go.
SOURCE: The belt has been replaced but the roller will
remove and inspect the roller -- check to make sure there is no hair or carpet strands tangled up on the edges -- use a teflon/silicone based lubrication to lubricate the bearings,, re-install the roller ( without the belt on ) and see if it now turns freely --- if it does, then install the belt and re-
assemble unit and all should be good from there. but if it does not turn freely then it could be a bad bearing and just the bearing needs to be replaced,, you can get the bearings at your local vacume repair shop - also a small appliance repair shop might have them in stock or be able to order them.
c...
SOURCE: Need to replace the broken
Hi edtb,
Put the belt on the motor first, Then, insert the brush roll into
the other end of the belt. Insert the left side of the brush roll into
the power head. Push the right side of the roller into the power head
until both ends are fully seated in the slot.
Don't worry that the belt appears to be too large.
Reassemble.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
