Question about Cell Phones
My mobile charging is reducing very fast - Cell Phones
    President:
  • 2,110 Answers
It seems U have to replace the battery...
Posted on Dec 03, 2008
Why does the Battery Drop so fast On Samsung tablets
mostly it depends on your usage, more the usage faster the battery drop.
In general, below are few ways you can reduce your battery drop.
1. keep screen brightness moderate or low
2. User power saver
3. dont keep your tab for charging for longer time, it reduces battery life (eg, you might keep it charging before sleep until morning)
4. Kill all background running apps when not needed
4. check your carrier signal strength, use airplane mode when there is not network
5. keep in sleep mode when you are not using (just hit lock button
Jun 23, 2017 | Samsung Tablets & eReaders
Tip
Charging you laptop battery by Ultra fast charger
Some producers argue charger incredibly reduced charging times of 30 minutes or less. Cells with well-balanced and operating at moderate temperature, nickel-cadmium Dell Inspiron 1525 Batteries designed for fast charging can indeed be applied in a very short time. This is done simply dumped in a high charge current during the first 70% of the charge cycle.
In the second phase of the charge cycle, the charge current should be lowered. The absorption efficiency of the Asus M6000N battery charge is reduced gradually shifts to a higher charge state. If the charge current is still too high in the later part of the charging cycle, the excess energy is transformed into heat and high pressure cell. Eventually, the ventilation will occur, releasing oxygen and hydrogen. Not only reduce the gases escaping the electrolyte is highly flammable! A white powdery substance accumulating in the mouth area indicates the previous outburst.
Ultra-fast charging can only be applied to Dell PC764 battery that are designed for rapid recharge. Applying a high current charge for normal cells will cause the conductive path to heat up. The contacts on the portable packages also suffer if the current arrangements for contact management piston spring is undervalued. These contacts can wear out prematurely. Often, a fine and almost invisible crater appears on the tip of the contact, causing a high resistive path and forms an insulator. The heat generated by a bad contact often melts the plastic. touch voltages exceeding improve the flow of current.
old Dell Inspiron 1501 Battery with high internal resistance and the corresponding cells do not lend themselves to ultra-fast charging, even if they were designed for it. Low conductivity cell is transformed into heat, which further deteriorates the cells. Weak cells which have less capacity are fully charged before the others and begin to heat up quickly. Some HP 530 battery create enough heat to soften and distort the plastic case. Temperature sensing is a prerequisite for rapid and ultra-fast charging.
Several manufacturers offer chargers wrist. Interspersing short bursts of discharge between each pulse of charge can further increase the charge. This method promotes the recombination of oxygen and hydrogen gas, resulting in accumulation of reduced pressure and temperature of the lower cell. Pulse chargers are also known to reduce the crystalline formation (memory) for Nickel-based. Most of the Cadex Inspiron 1525 Battery charger for dv8000 Battery based on nickel implement this function.
Some advanced chargers adjust the charge current according to Dell Inspiron 9300 Battery capacity to accept charge. A DELL E1505 Battery takes a charge initially very high current. Towards the end of a tax, the current is tapered down. batteries have aged since their respect and are automatically charged at rates appropriate to their condition.
on Apr 21, 2010 | Computers & Internet
Mobility scooter goes slow
driving range of 20 to 38 miles per charge depending on unit. Check out our E Wheels electric power bikes, and mopeds that goes 20 plus mph. Want a fast outdoor mobility scooter, check out the EW - 36 that goes 15 mph. This deluxe outdoor power scooter has a driving range of about 25 miles per charge, depending on the terrain and the weight of the user.
Jan 21, 2012 | Health & Beauty
Last friday i bought the new HTC wildfire A3333 mobile nd put into charge for 8 hrs. The other day when i start to using one point of battery icon reduced nd on the same day i didnt nt use phone more. bt...
There could be 3 different things wrong:
1.) Battery is no good.
2.) Charger is no good.
3.) The port where you plug the charger into the phone is no good.
I would take it to your local mobile provider and ask them to test the phone, battery and charger. They will be able to tell you which one it is...battery and charger are pretty cheap fixes. If it is the port, you normally are better off getting a new phone.
Aug 22, 2011 | Cell Phones
Why its battery quickly drains
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 18, 2011 | Motorola Mobility C168 Cellular Phone
Need to unlock my phone
hi there are many ways to unlock the mobile we can use software,cable codes to unlock.Among them codes work better because it mainly save our time and money a lot and it reduce the strain .you can visit here to get the codes to unlock your mobile
prounlocking
here select the country where you brought the mobile and the provider which locks your mobile .then they ask you the imei number of your mobile finally they will render you the unlock codes as fast as possible.
May 25, 2011 | Nokia 2730 Cell Phone
Bettry charge is fast Reducing
hi thanks for using fixya!
Try to change the battery to anew and make sure that you will use the original battery.
Regards!
Jun 02, 2009 | Nokia N70 Cellular Phone
Sony ericsson mobile company toll free number give me(my id-kumaran25@gmail.com)
Call us at the following number:
- 1800 11 1800 (Toll free)
- +91 (011) 39011111 (from mobile phone)(not toll free)
Mar 04, 2009 | Sony Ericsson K530i Cellular Phone
I have a charging problem
a have w555 mobile phone  this mobile batry is calling time to fast low and ply time in batry to fhast low so pls idea
Dec 09, 2008 | Sony Ericsson W550i Cellular Phone
Fast battery drain only 6 hours standby (new battery)
i think some of the motorola mobile phones has a fast battery drain..
Feb 24, 2008 | Motorola Mobility E398 Cellular Phone
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
