Question about Keurig B60 Coffee Maker
My Keurig B60 is suddenly not dispensing water when a K-cup is in the machine. Dispenses fine with no cup in chamber.
  • 5 more comments
  • Anonymous Dec 07, 2008
    i have the same problem..........please help!
  • gbern901 Dec 14, 2008
    I have the same problem. When the coffee maker was new there seemed to be a small blast of air that forced out the water from the K-cup. That doesn't seem to be happening and the K-cup is full of water. I cleaned the exit needle, No difference.
  • darsco92 Feb 12, 2009
    I have the exact same problem.Maker work fine without a K-cup in the chamber.As soon as I put K-cup in, no water comes out.
  • born2bluvd2 Feb 24, 2009
    I have the same problem as well. I do hear the burst of air like it's about to brew, then nothing. Works well without a K-cup.
  • Anonymous Mar 09, 2009
    We have the exact same problem. It also gives out a little 'whine' noise. We have gone through 3 different machines every 4 months because of this!
  • RaleighJosh Apr 14, 2009
    Same here, at the office today it suddenly stopped working but only when a K-cup is inside. Runs fine w/o a k-cup. Tried cleaning but no use. Anyone have any insight?
  • DrFeelGod May 11, 2010
    Generally speaking:
    Are you sure that the handle is all firmly locked and in place?
    So that the K-cup isn't blocking something.
    Try to press the handle/"jaws" firmly (but not too firm) together to see if there is a weak spot that has been bent (indicated by "ready to brew" suddenly showing in the display)
I solved it by running the machine a couple of times without a K cup in it. The second time through, a few grinds ended up in the cup. After that, the machine works fine.
Posted on Jan 19, 2010
Try changing the cup setting. My machine stopped dispensing water to the K-cup when I was using it on the smallest cup setting. I could hear what sounded like air being pumped. I tried turning it on and off, and cleaning the needles, to no avail. What finally worked was changing to the largest cup setting. Immediately water was pumped from the reservoir to heat, and a full cup was produced. It also started working again on the small cup setting.
Posted on Dec 29, 2010
    Problem Solver:
  • 5 Answers
May be blocked needle valve in k cup holder. Remove and take apart. Try then using a paper clip to dislodge any grinds blocking hole.
Posted on Aug 12, 2009
My B66 usually stops dispensing well before the cup size is reached. SOmetimes it over dispenses.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 20, 2011 | Keurig B60 Coffee Maker
When my Keurig one cup dispenses the hot water onto the filter the water goes everywhere (making a mess) but not through the coffee filter & grounds.
Possible clogged water output house. Question? Is the water going on the filter then overflowing? If so, the grind of the coffee might be to fine. Might have to have the grounds a little courser. To test put no coffee in and if flows through ok, then coffee is ground to fine, then just need to have it ground a little courser. Thanks, mike
Jun 08, 2011 | Keurig B60 Coffee Maker
My keurig only dispenses half of a cup of coffee. Half the water comes through the kcup and the other half is despensed back into the water reservoir
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Nov 03, 2010 | Keurig B60 Coffee Maker
Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Mar 25, 2010 | Keurig B60 Coffee Maker
Keurig B60
Check the needle inside the k-cup holder to ensure it is not clogged. You can completely remove the k-cup holder by pushing up from the bottom (where it dispenses into your coffee cup). Then rinse it out with hot water using your kitchen sink sprayer. The manufacturer also recommends inserting the tip of a small paper clip into the needle to push out any debris if needed. Then replace the k-cup holder by aligning the arrows and snapping it back into place. Next try to brew your regular cup of coffee and see if that fixed the problem. Hope that worked for you...Best of luck!
Aug 29, 2009 | Keurig B60 Coffee Maker
My Keurig dispenses about 3oz of water on next to largest setting
I JUST fixed (I Hope!) my 11 month old B60 by taking a paper clip and a straightened safety pin to the top of the coffee maker (where the top pin punctures the top of the cup) and the BOTTOM pin which punctures the bottom of the cup. (remove the bottom dark brown holder by pushing up on it).
After one or two attempts, I ran water through it without the coffee cup, then used a decaf cup and brewed it just fine....
Aug 25, 2009 | Keurig Platinum B70 Coffee Maker
Keurig B60 coffeemaker stopped pumping water because I didn't notice there was almost no water left in the chamber and started it--I added water right away but it won't pump any more water out of the...
This morning my Keurig sounds like it begins to pull water then stops. I tried to cut it off then back on. Still didn't work.Removed water from reservoir and K-cup and added pure vinegar. Ran machine several times without filter or Kcup by pressing cup selector several times. You must open K-cup holder and close each time. I had to do this about a dozen times before the water began to draw again. Flushed system by filling water reservoir with fresh water, and brewed just plain water until vinegar was gone.Works like brand new.
Nov 11, 2008 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
1,412 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
