Question about Samsung SMH7178STD Microwave Oven
Samsung SMH7178STD microwave fan stopped working
Low and medium speed of fan don't work, but high speed called "turbo" works fine. This is the vent fan. When fan quit working, it popped and also blew out both lights in base of this wall-mounted unit. 2- 40w bulbs. Mic seems to be working just fine, heating things up, etc. didn't trip a breaker. replaced bulbs thinking that somehow was related and the whole light part doesn't work either.
Any help appreciated!
Thank you for a great site.
  • 78 Answers
It looks like the part of your computer board on microwave which responsible for controlling light and fan stop working. In this case you have to replace computer board.
Posted on Dec 03, 2008
Whirlpool microwave fan not working
I would unplug the oven for 2 minutes to do a hard reset and try it again, just in cause there was a glitch.
Without knowing your full model number from the tag on the oven, I would wonder if it has a separate internal cooling fan from the hood vent exhaust fan. It could be an unrelated issue.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | Microwave Ovens
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
Vent fan has stopped working. the keypad says vent fan off. when pressing help, it says press this pad. nothing happens.
A low tech solution worked for me.
I too was getting the "Vent Fan Off" message, and despite the fact that everything else worked fine with the microwave, I turned the breaker off and back on from my electrical panel. The fan works fine now.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
During cooking, the microwave will work for about 3 minutes then completely shut down.There appears to be a complete power failure.After the units sits for about 5 minutes,it resets itself and you can cook...
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
Oct 20, 2009 | Samsung SMH7178STD Microwave Oven
Fan and cook top lights no working (samsung SMH7175WC microwave)
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 10, 2009 | Samsung SMH7178STD Microwave Oven
Deep humming sound
This usually means the magnetron is failing.
Just be sure the internal cooling fan is working by making sure you feel air flow. If not, call for service right away.
The magnetron part cost is covered beyond the normal 1-year warranty, so when it gets worse or stops heating, you'll have to call for service.
To find an authorized Samsung servicer, look here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 04, 2008 | Samsung SMH7178STD Microwave Oven
Fan vent door not working
First of all, if it's less than a year old, it will be under warranty and you should contact Samsung to cover the service. You can try the number in your manual or try samsung.com
There is a drive motor that opens and closes the vent fan door. It or an associated switch may have failed.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number (SMH7178STD) at http://www.wehaveparts.com
Nov 15, 2007 | Samsung SMH7178STD Microwave Oven
Samsung Microwave model # SMH7178STD just stopped working.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find Samsung-specific parts here: http://www.samsungparts.com/search/search.asp
Nov 04, 2007 | Samsung SMH7178STD Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
Microwave Ovens Logo
311 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
