Question about Polycom VSX 7000 Video Conference
Can not able to dial out any number from Polycom VSX 7000.
Problem is while dialing any number from Polycom VSX7000 thru ISDN BRI lines, an error is coming that Destination address is invalid please check the address.
  • andy9940 Apr 03, 2009
    the far end did not support the requested channel type. contact your network administrator for assistance.
    Problem Solver:
  • 10 Answers
Check out the following things:-
1. When dialing a ISDN number, be sure that the call preference has not been set to IP H.323 on the home screen just below the dialing field.
2. Check with your service provider that outwards dialling have been enabled on the lines provided to you.
Posted on Apr 02, 2009
  • jacekronczka Feb 07, 2011
    @chinku42us
    I've similar problem like posted. When i change call preference to ISDN on home screen, dialing phone number it automaticaly switch to H.323. Is there any option to change preference ? In Net-> call preference i haven't seen such option.
My videocon tv having automatically av/tv switching problem what is its solution
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 09, 2014 | Polycom VSX7000 Videoconferencing System...
No AGC output,not normal colour
Pls can you ellaborate more on the problem...
Apr 12, 2014 | Polycom VSX7000 Videoconferencing System...
What does QUAD BRI stand for?
It means that there are four ISDN BRI S/T interfaces on the device. Each BRI line contains two phone numbers at 64Kbps of bandwidth each so the Quad BRI would supply 128Kbps x 4 or 512Kbps of bandwidth.
Feb 09, 2011 | Polycom Quad Bri Module for VSX7000S & Vsx...
My VSX 7000S does not recognize the microphone. It is connected to VSX\r\ncamera by the brown RJ11 cable with ferrite end to the camera but no sound is picked up and system status indicates "no...
You need to go into the audio settings via
Admin Settings
Audio Settings
and make sure Enable Polycom Microphone is checked off.
Reboot and see if your microphone is recognized.
Jan 13, 2011 | Polycom VSX7000 Videoconferencing System...
Manual option apears on my home screen , why its come and how i can remove that ?
If you asking for the manual option of ISDN and IP, then got to call preference and change the dialing method to auto
Jun 18, 2010 | Polycom VSX7000 Videoconferencing System...
Speed on vsx 7000 appears stuck at 64k
configure Bri Board as trunk in MSN config.  Create isdn trunk and add bri port to this trunk. Create routing to this trunk for VC number.
Dec 08, 2008 | Polycom VSX 7000 Video Conference
Can't get to the home screen
I've just solved that problem in the VSX 7000 of my girlfriend's Job.
Your VSX7000 has at least 4 video outputs, 1 for VGA and Supervideo 1 and Supervideo 2.
Firstly you should try VGA connector, because the main menu may be there, so you could change the configuracion.
If you can't see main screen in any of the output connectors you'll have to use the http tool.
In your internet browser enter the camera IP address, and you'll get the Web Interface of the VSX7000.
It will prompt you for user & password, the default options are "Admin" and your VSX7000 serial number (14 digits) you can find this number under the camera.
Once you're in the Web Main Menu, click on Site Map. There you can choose what you want to see in the screen of Monitor1 (My menus are in Spanish, maybe your menu says something like "screens" but I'm sure you'll find it)
If you choose Monitor/Screen 1 as Svideo, and select it as output for Local, Remote and Content you should see the Main Menu after the VSX7000 Reboots.
I hope it would be useful for you, if you have any problem with this let me know... This VSX7000 is working fine now, so yours should work!
Sep 19, 2007 | Polycom VSX 7000 Video Conference
Polycom VSX 7000 Video Conference Logo
1,871 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
