Question about Bosch HBL 745 Stainless Steel Electric Single Oven
HBN 745 stays on forever
The back coil of the oven stays on always. I end up needing to shut down the electricity to turn the oven off.
The oven seems to work fine otherwise.
  • Anonymous Apr 01, 2009
    oven will not turn off
  • 76 Answers
Got a short in your switch
Posted on Dec 03, 2008
I have a Bosch hbn 3650 and it has stopped working when u turn the knobs the clock still works but nothing else
I need more info electric or gas? If electric you need 240 volts or two legs of 120v. some times the clock will work even when you lost the other leg of 120v. Unplug or shut off breaker for about 1 min. if that doesn't solve problem pull plug and check wire connections at the other end of plug connected to stove. sometimes they become loose and cause damage to wire connector and wires. if wires are tight and no damage, check all other wires for tightness and damage. Sorry I need more info
Apr 29, 2014 | Ovens
Self cleaning
Set back on self clean, then after about a minute, switch off. The lock should disengage.
Apr 25, 2013 | Bosch HBN 442 / HBN446 Electric Single...
Oven does not heat to selected temperature.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 13, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
My Bosch double oven timer is not working. No clock, notimer, but the oven is working fine.
Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
Sep 19, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
Bosch HBN745 Single Convetion Oven - Fan won't stop & still maintains heat
Sounds like it is the thermostat that is faulty.
Go to your browser bar and type in youtube.com
Then in the search box type in fitting thermostat to oven
Click on appropiate video and follow instructions, this should help with your prob.
Thanks.
youtube.com
Dec 29, 2008 | Bosch HBN 745 Stainless Steel Electric...
Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
Bosch HBL 745 Stainless Steel Electric Single Oven Logo
233 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
