Question about Philips Televison & Video
Philips lcd tv model: 32PFL5203/98 1.5 months old when tv switched on the standby light kicks in and starts flashing red. I have done a hard shut down and restarted tv some hours later but still same thing. Cannot go past this point
SOURCE: Hitachi 50in. Ultravision Model #50ux14b
Vertical output chip has some ring cracks on leads (cold solder joints). Set is shutting brightness off to protect5 it's crts from burning a black streak across them.
Posted on Oct 03, 2007
  • 579 Answers
SOURCE: problem with tv
Pretty typical for lamp life. Buy a new bulb (not the whole lamp assy) from us (sedonix.com) or one of the many bulb sources on the net, install it yourself and save a lot.
Posted on Dec 31, 2007
SOURCE: Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Posted on Jan 05, 2008
SOURCE: flashing red light
light bulb
Posted on Mar 27, 2008
  • 3 Answers
SOURCE: Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Posted on Jan 05, 2009
The red standby light flashes constantly, we are unable to use set. We have been told to unplug all connection to the set, leave for one hour then restart, we have done this, ITS JUST THE...
You have tried the first thing I would suggest. Next count the number of times the light flashes. It should flash in a pattern approximately one sec apart, then pause 3 seconds and start the same sequence over. The number of blinks will help narrow down the area of the problem. I suspect it is either in the HV section or the power supply. Have you had a power bump recently? Lightning strike? Anyone else in the neighborhood have trouble? Find out the additional information and get back to me and I will try to help you out.
hardrocko
Feb 01, 2010 | Philips 32PFL5403D/27 32 in. LCD TV
I have a technika lcd tv/dvd. It is only a few months old but it is stuck in standby with the red light on the front continually flashing and will do nothing else. Any ideas?
I have same unit (which works in my case) but the red light does not flash on 'Standby', only when it is seeking a station after pressing the red button on the remote.
Nov 16, 2009 | Televison & Video
Magnavox LCD HDTV starts on its own since last few months and sometimes it changes channel on its own. This problem happens intermittently and really apprecaite fix for this. This TV is 15 months old.
it either needs new front switch panel or new signal module, turn the tv on and disconnect the front switch board if it quits doing things on it's own you need a new front switch panel, if it still does functions on it's own you need a new signal board.
Sep 08, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
Jun 27, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Jun 04, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Standby Indicator flashing SONY KD-32NX100UWhen I turn the TV on the TV goes straight into standby red light, I press the on button on the remote and the TV comes on for about twenty seconds then it...
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Nov 19, 2008 | Sony KV-35S42 35" TV
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
132 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
