Question about Mitsubishi WS-65809 65" Rear Projection Television
Locked out of older Mitsubishi VS4503R. Need owners manual/help!
I have an older Mitsubishi television. The plate on the back has the following model number: VS4503R.
The set is completely locked out.
Been using a universal remote on it and everything was fine. I tried to hook up a VCR to it and then I got locked out.
Can someone give me some info?!
Thanks,
Scott
  • chimdust Dec 06, 2008
    Thanks for your suggestion - I'll give it a try next time I'm at this house.
    I do have an old clunker Mitsubishi remote that came with the TV (it was given to me) although I am not sure if it is the original.
    Thanks again!
  • 505 Answers
If you are locked out of the inputs, you need a original Mits remote. Push QV and the 9 button simultaneously to unlock temporarily. Some models its the SQV button and 9. This will let you get in to change the code. You can also get a simmilar issues with the active AV network turned on, it will lock it to a set input (ie input 1). Try going into the menu and turning the av network off.
Posted on Dec 06, 2008
Tip
Mitsubishi WS-65712 Manual Download
Download Mitsubishi WS-65712 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-65712 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65712 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Bypass Mitsubishi WS-65712 Front Lock
Reset Mitsubishi WS-65712 VChip Password
on May 05, 2010 | Mitsubishi WS-65712 65" Rear Projection...
How to reset personal identifaction code (PIC), for mitsubishi 42 inch big screen tv, model #VS4503R. Input is locked until the PIC is entered
Did you do a hard reset? (Just unplug the power cord for 4 hours, then try again. It may help; I will give it a 50/50 chance).
If the reset does not help, go into the osd and reset all the feature/parameters that relate in any way to zoom and see if that will relieve it. Even the caption setting should be checked for correct function.
If the reset and the OSD check does not help, you will need service. It is probably the controller IC (this is one that regulates the overall operation of the set). The zoom is needed in order to change the picture aspect ratio for 16/9 hd as well as regular square tv.
Oct 11, 2009 | Televison & Video
Tip
Mitsubishi WS-65711 Manual Download
Download Mitsubishi WS-65711 HDTV Manual
Have you misplaced your Mitsubishi WS-65711 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65711 HDTV Users Guide?
I hope that helps.
Reset Mitsubishi WS-65711 VChip Password
Bypass Mitsubishi WS-65711 Front Lock
on May 04, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Tip
Mitsubishi WS-65611 Manual Download
Download Mitsubishi WS-65611 HDTV Manual
Have you misplaced your Mitsubishi WS-65611 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65611 HDTV Users Guide?
I hope that helps.
Reset Mitsubishi WS-65611 VChip Password
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Unlock code
while the tv is on, unplug it for 20 seconds, then plug it back in, should turn itself back on, but if it dont, turn it back in yourself, most of the time it will fix the issue
Jan 11, 2009 | Televison & Video
Tip
Mitsubishi WS-65511 Manual Download
Download Mitsubishi WS-65511 HDTV Manual
Have you misplaced your Mitsubishi WS-65511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65511 HDTV Users Guide?
I hope that helps.
Reset Mitsubishi WS-65511 VChip Password
Bypass Mitsubishi WS-65511 Front Lock
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Mitsubishi WS-55711 Manual Download
Download Mitsubishi WS-48511 HDTV Manual
Have you misplaced your Mitsubishi WS-55711 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55711 HDTV Users Guide?
I hope that helps.
Reset Mitsubishi WS-55711 VChip Password
Bypass Mitsubishi WS-55711 Front Lock
on May 03, 2010 | Mitsubishi WS-55711 55" Rear Projection...
Tip
Mitsubishi WS-48511 Manual Download
Have you misplaced your Mitsubishi WS-48511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-48511 HDTV Users Guide?
I hope that helps.
Reset Mitsubishi WS-48511 VChip Password
Bypass Mitsubishi WS-48511 Front Lock
on May 03, 2010 | Mitsubishi WS48511 48" Rear Projection...
Tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
I hope that helps.
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
169 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
