I have plugged a 12 volt transformer into my ZOOM G2 guitar effects by mistake.Now it does`nt work (duh!).Is it completely broken
  • 76 Answers
Yep
Posted on Dec 03, 2008
How can I mix the sound of the Zoom A2 and the dry sound of the guitar?
the easiest way to mix less effect sound and more natural guitar sound is to reduce the level of the individual effects within the patch selected. The more challenging method would be to go through a splitter box 1st, or any stereo effects box, to split the signal, and then you will have 2 outputs, one dry, one through the Zoom. The 3rd (and simplest ) method would be to place the Zoom in the effects loop of an amp that features a send / return balance adjustment.
Aug 31, 2016 | Zoom Music
Wat type of voltage regulator ic is used
2933BD or 29M33. It is used in g1, g1x,g1xn,g2,g2iu etc.
This is 3.3 volts regulator ic.
My thread.Tommi.
Jun 24, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
What type of voltage regulator ic used in g1x?
Feb 09, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
The zoom g1x is dead. no power. tried adapter from my other zoom pedal but nothing. opened it up and everything seems in tact. was working fine saturday, dead sunday. only one month old.
The first thing i would check is the ac adapter .Make sure you are getting the correct voltage from the adapter.If you know how to use a voltmeter or know someone that has a volt meter,check it with it unplugged from the guitar pedal,most of these have a voltage range from 9 to 12 volts dc.you could also take it to your local radio shack or local repair shop and they will be glad to check it for you for free.after you confirm the adapter and it is ok then the next thing you will check is the input jack assy on the pedal,input jack assy are soldered onto the board at the factory,these jacks ,no matter what it is are famous for cracked solder joints where the pins of the jack go into the board because of stress delivered to it during plug ins and plug outs.if you dont know how to use a sldering gun or dont want to you will have to take it it to your local repair shop-cost should be around 15.00, 20.00 tops,make sure that your guitar cables are good,check the 9volt battery inside the unit if it takes one,if its dead that could be your problem,if all above fails i would send it back to the factory or wherever you bought it.,good luck been playing for about 30 years myself,rock on
Jan 24, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
Can the zoom g2g plug straight into a speaker cabinet
No. You will need to use an amplifier, home stereo, P.A.etc. I would recommend insertion in an effects loop if your amp has one.
Dec 13, 2010 | Samson Technology Zoom G2g George Lynch G2...
I have a Zoom 9000 Guitar effects processor, and although I have its original adapter, and although its red light flashes and power is on after plugging in everything, I could not get any sound from my...
I'm a Zoom 9000 owner (since '93, I think) Did you try batteries only? Are you plugging the guitar into the "in / power" jack and not mistakenly using another jack? When you plug in the guitar, in to the Zoom 9000 does the window come on with the settings shown? Sorry, I know some of these are obvious but always the chance of us being human. If all that seems fine, then I would read though a manual to see if maybe it is a setting problem, i.e., sound somehow got inadvertently turned off. If you don't have one, an internet search will lead you to one. Sorry, wish I knew more.
Oct 14, 2010 | Zoom A2 Acoustic Effects Pedal
No power
There is a possibility that the receptacle for the adapter plug has one or more broken solder joints on the circuit board.
Mar 22, 2009 | Music
70 people viewed this question
 Grubhead
Grubhead
