My sound is not working it is telling me under volume that there is no audio device
  • 4 Answers
You need to install the Sound Card Driver...
But first I need the Brand & Model #
Posted on Dec 03, 2008
While i load window 7 sound driver not working
This appears to be a pretty old motherboard. To start with, check the volume control near the clock in the right side of the taskbar. If there is an X look at why - it is possible your speakers aren't plugged into the right place (try the green plug). Or your volume may be turned down all the way on the speakers or the volume control or the mute might be selected (just uncheck it or move the volume slider a little bit).
If those easy things don't work, there is a driver for Vista for your motherboard, so that same driver should (but no guarantees) work for Windows 7 - make sure you know whether your OS is 32 or 64 bit - there are two easy ways to tell.
First, open an Explorer window using the folder icon in the Taskbar, and click the little triangle next to the C: drive. If there are two Program Files folders (one with x86) then you have 64 bit. If not, you have 32. The other way to tell is to go to the Control Panel, show Large Icons, and double-click System. It will tell you whether your OS is 32 or 64 bit.
Here is the link for the driver from Asus: http://support.asus.com/download.aspx?SLanguage=en&m=P5PE-VM&os=17
Be sure to download the correct driver. Install it and it should work. If it does not work, the sound card on the motherboard may be bad. It is also possible the audio portion of the motherboard is turned off in the BIOS setup program. Look in the Device Manager in the Control Panel under Sound, Video, and Game Controllers for a specific device such as Realtek High Definition Audio Device or something similar, or there may be something under Other Devices like 'PCI audio controller' or something to that effect.
If those are missing, try going into the BIOS setup program by rebooting your computer and right as you see the Asus splashscreen press the Delete key on your motherboard. Look under Advanced Options or something similar to see if the Audio bus is turned off - if it is then turn it on.
If nothing works, you should be able to get an add-on PCI sound card from a place like Newegg (I like Soundblaster cards) and install it.
I hope that helps!
Dave
Oct 21, 2013 | ASUS P5PE-VM Motherboard
I can't seem to get PowerPoint to pick up the sound from the microphone..... I have tried every conceivable setting under the sun.... Using Microsoft XP.... Message telling me to go to Multimedia...
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Mar 01, 2011 | Dynex Voice-Certified PC Desktop...
I cant get any sound on my computer. it is telling meno audio output device installed. and is pluged in
Please just follow the steps to fix the problem
  1. Step 1 From the Task bar located at the bottom of your computer click once on the "Volume" icon.
  2. Step 2 Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
  3. Step 3 Right click on the "Volume" icon.
  4. Step 4 Select "Open Volume Control."
  5. Step 5 Uncheck all of the boxes next to "Mute" in the Master Volume, Wave, SW synthesizer, CD Volume, Mic Volume, Line Volume and PC Beep selections. If this does not resolve your sound issue, proceed to step 6.
  6. Step 6 Right click on the "Volume Control" icon.
  7. Step 7 Select "Sounds and Audio Devices Properties."
  8. Step 8 Under the "Volume" tab, slide the "Device Volume" indicator to High.
  9. Step 9 Under the "Speaker Settings," click on "Speaker Volume."
  10. Step 10 Slide the "Left" and "Right" volume indicators to "High."
  11. Step 11 Click "OK." If this does not fix your sound issue, proceed to step 12.
  12. Step 12 Right click on the "Volume Control" icon.
  13. Step 13 Select "Sounds and Audio Devices Properties."
  14. Step 14 Go to the "Hardware" tab and select the "Driver" tab.
  15. Step 15 Make sure you are connected to the Internet and then, Click on "Update Driver."
  16. Step 16 After the driver has been updated, Click "OK."
  17. Step 17 Exit.
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 31, 2010 | E-Machines eMachines Desktop PC
My computer will no longer play music or any kind of noise
Check that your speakers are plugged into the right jack either in your sound card or the sound panel on the motherboard. If no sound then try plugging speakers into another computer and see if they are working and have power. Go to "control panel" and click on "Sound and Audio Devices" and under the volume tab under Device Volume make sure that the "Mute" box isn't checked. Also check the "place Volume icon in the taskbar" box if it isn't already checked. Go to the Volume control on the task bar and check out the audio volume levels and make sure they're not turned all the way off. Also under "Sound and Audio Devices" underl Volume tab click on "Advanced" and make sure that you have selected the proper kind of speakers in the speaker setup box.
YOu didn't say so, so I'm assuming that you're using Windows XP. If you're not the menus may be a little different but similar.
Sep 29, 2009 | Microsoft Windows XP Home Edition
Volume control program installation
go to the control panel, open the sound and audio.
check the box in front of "place volume icon in the taskbar", under the device volume, in the volume tab page.
Mar 17, 2009 | Microsoft Windows XP Home Edition
Problem in my speaker........
goto CONTROL PANEL>Sounds & audio Devices(icon). goto VOLUME, far left menu option.Just under VOLME you should see a ICON of a speaker & the name of the audio device\driver. [If you don't u don't have a audio device INSTALLED] Make sure that the MUTE is not checked.,place a check ['place volume icon in the taskbar] ( that is the RIGHT bottom)On the left bottom of the same"volme" click "speaker volume" and raise the volume. GOTO >SOUNDS(sbmenu)>program events(windows>Asterick,Close Prgram,critical Battery Alarm,Critical Stop,Default Beep,etc,etc)
UNDER:: sounds, look & see if a sound is "taged", just to the right there is a "right" arrow that should be BLACK. When you touch the "arrow" the sound that u "taged" should sound.(1st) goto AUDIO >Default device: you HAVE to see some type of "audio device" e.i. Sound Blaster, Conexant AMC ,ABC Bananers,some type of audio device! If not, left click mouse DARK "arrow" down to see if you have some type of adio device\driver.If so chooze it.(2nd) goto VOLUME AND raise the volume.(3rd) Go back to "sounds" & while you click the dark arrow facing right, connect the speaker jack to the back of the "FEMALE" port.Sometimes they are not marked and you could connect to the wrong port.example: mike in instead of speaker out. understand!
Jul 18, 2008 | Audio Players & Recorders
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
No Sound from Acer Aspire 5100 : Volume tab is disabled
hi I am linda
trying going into add and remove the whole thing then shut your pc down and reboot it after is rebooted try going to systems files and make sure your aduio deivce is still connected if it is n't I am supposeing your audio card mite be bad or reinstalling it mite take care of the promblem .
Apr 24, 2008 | Acer Aspire 5100 Notebook
Internal MIC not working
If you are using xp, try going to the control panel, sound and audio devices, click on audio tab.
to check the mic settings, click on the volume tab under the sound recording sections. Make sure that the mic is selected and the volume turned up. It may be working only to record, not to hearback without recording...so you may have to actually be recording or talking to someone to know if its workings.
To check the sound, check to see if your audio device is selected under "sound playback" section...and make sure that all channels are unmuted and turned up. you may also have to check the volume control on the laptop (actual buttons on the pc) if there are any, and make sure that the volume is up and unmuted there also.
Hope this helps.
Mar 30, 2008 | HP Compaq Presario V6000T Notebook
My computer
If your using any ver.of XP. Click the start button slide up to & open control panel. Double left click Sound and Audio devices icon.
Sound an Audio Device Properties window will open. Click the Audio tab. Under Default device: is the sound cards name. Click the Voice tab. The same device name should be listed under Default device. Lastly click the Volume tab. Put a check in the box (by clicking one on the emty box), next to, Place volume icon in the taskbar. Within seconds your volume controll will show up down by the clock.
Have more questions, feel free to ask.
Good Luck!
Mike
Mar 26, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
