Question about Toshiba RD-XS52 DVD Recorder
Toshiba DVD recorder problem
My toshiba RD-KX50 DVD recorder (RD-XS52 equivalent) freeze randomly Sometime he worked fine 15-20 min then freeze, sometime he freeze immediately after the startup, seem completely random behaviour. When he freeze, he doesn't respond to any commands, even the shutdown button, i have to unplug the AC to restrart him. Apart the freeze problem, all function seem to worked fine Andre
  • Anonymous Mar 16, 2014
    How do I obtain a copy of the instruction manual?
Generally, this problem is caused by bad sectors or other problems on the hard drive and can be resolved by going into the setup menu and re-formatting the hard drive. Of course, all recordings on the hard drive will be erased, so spin them off to dvd first. Be sure to have unplugged and replugged the unit immediately prior to going into the setup menu (don't try to record anything). If this doesn't work, no-one will repair this unit locally, as it must be returned to Toshiba's(TACP) depot for repair. Best of luck.
Posted on May 15, 2007
Unlock code for toshiba dvr, rd-xs52 I want to be able to record protected media.
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Pull up older posts. You can gather all details. Sometimes, click open the adverts' by the side and bottom of each post might give you more details.
May 27, 2012 | Toshiba RD-XS52 DVD Recorder
DVR Set to DR-2, can't set it back to DR-1.
Just unplug the DVD cord from the power source and re-fix it after a minute or so. It's so simple. Please let me know if it works for u. setornam123@yahoo.com
Sep 26, 2010 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
Toshiba rd-kx50 recorder error 3B - HDMI doesn't recognize tv
WOW another person that kept the rd-kx50, Welcome brother or sister to the fold..lol.
I had that problem a couple of times, I just remove the hdmi cable while the tv and recorder are off, and then connect it once it's back on.
It's a pain to do this, but you could just use the component cables and not worry about the issue (at a slight cost of picture quality)
Apr 23, 2010 | Televison & Video
Hi, I have a toshiba RD-XS52 that requires a firmware update before HDMI will work with newer model TV. Have tried to download and run update link provided by tosiba with 10 pouched discs. Any thoughts?
I tried the firmware found on Toshiba Canada website, it doesn't work. I believe the US version of RD-XS52 firmware is not upgradeable. The site said the firmware is for RD-XS52SC. You guys got it to work?
Jan 19, 2009 | Toshiba RD-XS52 DVD Recorder
Toshiba RD 85DT DVD recorder
ok you need to press STAR Button which says mode above it and either 1,2 or 3 to find which freqency is being use. The dvd and the remote need to be on the smae on.
Oct 18, 2008 | Toshiba RD-XS52 DVD Recorder
Toshiba RD-KX50 HDMI freezes the recorder.
Press the standby button for about 10 seconds and will reset the HDD you may lose what you have on the HDD but will fix it.
May 07, 2008 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
TOSHIBA dvd PLAYER/RECORDER sd-V394
You could try clening the laser lens with a damp Q-Tip, also gently turn the spin motor spindle by hand... it should be free. If it's binding or tight then it's bad.
Geno
Mar 05, 2008 | Toshiba D-R2 DVD Recorder
Remote control
Search for toshiba P000416560 on google. Many companies sell this remote. It'll cost about $35.00 or so.
Mar 01, 2008 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
Open Questions:
Toshiba RD-XS55-S-TU corruption of video after firmware update This recorder is around 2 years old and was functioning fine. Occasionally I'd have a problem with corrupt pixels when copying from DVD-RAM to the HDD (never from DVD-R for some reason). I complained several times to Toshiba and they claimed since I am in Japan it is due to the Hz issue (50 Hz versus 60 Hz). I do use a transformer to provide 120 volts. However pulling the plug for 3+ minutes usually solves the problem. I upgraded to the latest firmware hoping it would solve these issues. At the termination of the update, the last couple of steps of the instructions did not occur (similar to another poster complaining of this problem). I pressed the standby switch for 10+ seconds but I did not get a 'Wait' message nor did the tray close automatically. I had to pull the plug to gain access to the recorder. The recorder starts up fine, except I have a chronic problem with corrupt pixels now whenever I dub from DVD-RAM to HDD. I have tried pulling the plug for hours and as long as a day, but no help. I also have problems with the recorder locking up during scheduled recordings: I turn on the TV and the image is locked in mid recording and none of the buttons on the recorder works to turn it off so I have to pull the plug. Of course I lose the recording and all scheduled recordings after that. Sometimes the audio would just plain fail. Toshiba wants me to send the unit in for repair at a cost of $150 but freight by U.S. Postal Service from my FPO AP address to the U.S. will run $40! I told them why should I pay for repair when it was caused by their firmware update??? I notice they have subsequently pulled the firmware file from their site, no doubt due to my complaints. Any suggestions on how to fix the recorder and/or get Toshiba to repair it at no charge, which I feel is a fair demand? I have already tried to format the HDD several times (using the Toshiba instructions via the recorder) and tried the firmware update again 3X to no avail. I even tried to use the Canadian firmware update for this unit but the recorder won't recognize it.
Feb 27, 2017 | Toshiba RD-XS52 DVD Recorder
Toshiba RD-XS52 DVD Recorder Logo
448 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
