Question about Acronis Migrate Easy 7.0 (AME7)
MIGRATE EASY SOFTWARE-PARTION SIZE DID NOT INCREASE
I have Dell Dimesion 4300S with Win2k pro as OS. I had 130GB IDE and now got a 320gb HD. Using Migrate Easy trial software, I migrated to the new HD. For partition, I used "proportionate" so that new HD's partion expands. The new master HD does not show 320gb in Explorer (in bootup setup screen, it correctly shows 320GB), instead it shows the same as the old 130gb. What went wrong?
  • MTAKASHI Dec 03, 2008
    I use Win2kpro, not Vista. so this does not work.
  • MTAKASHI Dec 04, 2008
    I downloaded Ultimate Boot CD (UBCD), but none of the software in it
    seems to support NT NTFS; they seem to support only FAT. Do you know of
    any software to expand NTFS partion (of course without destroying the
    data in it)?
  • 76 Answers
When u clone a drive it copies the same size to if you are using vista it is easy to expand go into admin tools then computer management then click on your drive and expand it
Posted on Dec 03, 2008
  • djishere Dec 03, 2008
    there is free software to expand it google it not difficult
Hcl laptop recovery
Some vendors have recovery partition software installed from the factory you can uninstall and it increases the HD automatically. (you will lose your recovery partition though) the other option is a software like Acronis that will repartition your drive on the fly. Careful though, this can be detrimental. FAT files can be sensitive. Also ensure your OS can handle the size you want to go to, or you will have failures there also, like it won't even see the partition!
Nov 02, 2013 | Microsoft Computers & Internet
I am using K8S MX Motherboard with OS-Windows XP. but my hard disk is not working. i want to purchase a new 160gb IDE hard drive. please tell me if it supports 160gb hard drive or not
The specs for this motherboard say it has a Utra-DMA 133, and 2 SATA 3Gbs ports.
You can connect any IDE HD, and any SATA 3 or lower HD. These standards are backwards compatible. When it comes to size, there is a 2TB MBR limit.
I would skip IDE and go directly with a SATA 3 drive.
http://www.asus.com/Motherboards/AMD_Socket_754/K8SMX/#specifications
GL
Dec 11, 2012 | ASUS K8S-MX Motherboard
Is a 320gb HD compatible with the Inspiron Dell laptop?
Hi, I think its compatible with Dell Inspiron as long as the 320GB uses the same cable like IDE or SATA with that dell inspiron, and I think if ever your machine right now uses on the IDE cable it can still handel a 320GB capacity because an IDE cable can accomodate up to 500GB size Harddrive. Also I would suggest that if this would work on your machine try partioning your 320GB to one 60GB for your operating system and the other space is for your data storage. Hope this helps
Jun 03, 2010 | Dell Inspiron 6000 Notebook
When I plug in my 320GB My Passport Western
It seems your HDs left over portion which is not showing is not formatted for the particular OS in which you are trying to copy. It is advised to backup your HD contents and format the HD with the OS from which you want to take data in the same FAT system which that OS is using.
Jun 15, 2009 | Western Digital Passport 320GB External...
I have the same HDD but system does not recognize the full size
hi there this is because of  unpartitioned disk space i.e, you wouldnt have partitioned rest of the memory while installing OS you would have only partitioned only 130gb tat is the reason it shows tat much :)
u create a partion then u will be able to use memory for its fullest :)
Apr 29, 2009 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
Dell dimension 4300s want to move hard drive to a new machine
You can move it but you have to remember that its going to have different hardware then your dell 4300 so it might require you to install drivers for the hardware that windows XP pro can't recognize. Keep that in mind so as long as you know where to go to get drivers for the hardware in that other machine, it won't be a problem.
Mar 02, 2009 | Dell Dimension 4300S Convertible...
I have Dell Dimesion 4300S with Win2k pro as OS. I had 130GB IDE and now got a 320gb HD. Using Migrate Easy trial software, I migrated to the new HD, for partiotion, I used "proportionate" so that new HD's...
Did you enable Copy NT Signature? If so, you need to unplug the old drive after cloning and BEFORE the first startup with the new drive. Two drives cannot use the same NT Signature on the same machine.
Dec 01, 2017 | Acronis Migrate Easy 7.0 (AME7)
ATI Radeon HD 2400 PRO - Win2k drivers
You can download a beta version of the driver for Win2k HERE
You could also download the ATI Catalyst Drivers Version 7.2 for Win2K/XP if you want from HERE
Hope that helps..Not sure if the CD in the box contains the software for Win2k though...
Apr 18, 2008 | Computers & Internet
HardDrive will not copy (or mirror) to another HD
Acronis Migrate Easy Trial
The Trial version of Acronis Migrate Easy is fully operational but works only for 15 days.
Acronis® Migrate Easy 7.0 file size 41.5MB
http://www.acronis.com/homecomputing/download/migrateeasy/
Dec 31, 2007 | ASUS VIA Apollo Pro133A Chipset CUV4X-C...
Acronis Migrate Easy 7.0 (AME7) Logo
164 people viewed this question
Top Acronis Computers & Internet Experts
richie46
tuffbird72
InHouseTeq
Are you an Acronis Computer and Internet Expert? Answer questions, earn points and help others
