Question about MediaFORM CD 3706 Burner
3706 partially burning, then rejecting cds
I own a Mediaform CD-3706 that i got from a salvage company for dirt-cheap. Needless to say, the unit did not come with a manual (if anyone has one, let me know!), but with a little online browsing i was able to figure out how to get it working.
I've been running it relatively constantly for almost 2 weeks now, burning a large project of 10,000 cds. After i'd successfully burned about 3000 cds i began encountering the following problem...
Occasionally, the duplicator will stop in the middle of (or after) a group of 6 cds is being burned and display an error message. When this happens, the arm moves all the way to the bottom of it's track and rests there, completely halting the whole duplication batch, and without even ejecting the cds from the drives. When i manually eject the cds it appears as though some of them were burned properly, where as others have very little information burned to them (i am judging this by looking at the bottom of the cds). I thought it might be the drives, but it seams to be happening randomely, and not consistant to any specific drives. It seams the more i duplicate, the more frequently this occurs. Does anyone know how I can prevent this from happening?
  • atgrain Dec 04, 2008
    Does this mean the drives need to be replaced or i need to allow time for the drives to rest between batches?
  • 76 Answers
Um your overheating the drive they do not last forever
Posted on Dec 03, 2008
  • djishere Dec 04, 2008
    better to buy a new one u might be burning alright sometimes but i bet they gunna be bad
  • atggraphics
    atggraphics Jul 31, 2012
    lowered the burn speed and it stopped the issue. been burning fine for 4 years now. and every one i've tested has worked fine
Cd carriage does not always load cd properly
Yes,as rightly suggested,dirts can cause the optical lens to reject some CDs.Use a a CD cleaner to clean the optical lens.If the problem persist,then you will need a qualified service personel to replace the lens.
Apr 07, 2014 | Bose Awrc1g Wave Radio Cd Player Only -...
4 cds stuck and want reject out
Your going to have to pull the unit and reove the top lid to get them out, Just be very careful not to breck anything inside the unit (CD player)
Jan 21, 2013 | 2006 Nissan Maxima SL
Is there any firmware or software to turn my MediaForm CD 3706 into a dvd burner?
There are no software ore firmware updates. I would contact MediaForm and see if they have a compatible dvd drive.
Dec 19, 2012 | MediaFORM CD 3706 Burner
Disc player picks up CDs, puts them down, they spin and then it picks them back up without playing them.
In my experience this is usually a problem with the CD player or the CD control unit. I have had this problem with my Wurlitzer CD Carnegie and I solved it by simply taking a Q-tip, moistening it with rubbing alcohol and lightly rubbing it on the CD player's laser lens and then using the other side of the Q-tip to dry it. Over time dust and dirt can build up on the lens causing read errors, which in turn cause the jukebox to reject the CD. If that does not help, I would suggest looking into replacing the CD player or the CD control unit.
Mar 26, 2011 | Wurlitzer Jukebox CD Player
How does the information get into the Mediaform cd-3703 I am new to using the burner
Was there a "User Guide" supplied with manual?
Does it contain instructions?
Since this seems to be a "bulk" CD-copier,
is it possible that FIRST insert the "master" CD, and let the copier read everything from that disk, and then you start inserting "blank" CDs, to make copies?
Nov 16, 2009 | MediaFORM CD 3703 Burner
My car wont play my cds.
replace the stereo its not worth fixing
Oct 17, 2009 | 1997 Mitsubishi Diamante
Need manual for mediaform 5908
To download the manual for MediaFORM CD5908, please click the below mentioned link:
MediaFORM CD 5908 manual
Thank you
Nov 22, 2008 | MediaFORM CD 5908 (CD-5908-8DR) CD-RW...
Error message E-8302
It sounds like you might have problems with your CDs. If you are burning CDs on your computer to play in the CDJ, you need to remember that it will only play audio (wav), or MP3 files. Also, blank data CDs are cheaper that buying audio / music CDs. When you burn your CDs to play back on the CDJ, you have to be sure to burn them as wav or mp3. AAC, MP4, OGG and the other formats will not work in the player. When you burn the CD, ALWAYS burn at a slower speed than what the computer will automatically burn at. You will have to manually set the speed yourself.
Personally- when i burn my tracks CDs for my CD book, I use trusted name brand blank data CDs such as Memorex, Sony, TDK, Fuji, Imation. I burn them as AUDIO ONLY. To avoid any reading mistakes that could happen with any given CD player, i NEVER burn track CDs as mp3. When i burn the CD, i set the writing speed to 24x, 30x, or 32x. I recommend that you DO NOT burn your CDs at any speed faster than 32x. From my experience, that is the fastest and safest burning speed. If you do these things, and you still have problems with the E-83 02 code, then it will only have to be the kind of CDs your using to burn, or your CD burner in your computer. Notice how i didn't mention Maxell CDs up top. 3 months ago, i bought 2 spindles of Maxell data blanks on sale for $9.99 each. I was happy i got them that cheap, but the CDs themselves were no good. Recording everything the way i do, they had popping noises and scratching sounds through-out the disc. I gave the spindles to my neighbor. He was happy to get blank CDs free. I WILL NOT say that Maxell makes a bad product: I still record on cassettes and Maxells are one of my top 3 choices for blank chrome tapes. But the discs i bought were just a bad batch. Maxell is still a trusted name for blank tapes with us older DJs that started out with recording on tapes before the CD format became way cheaper and affordable.
Try burning your discs as audio only, and burn them at 24x, 30x, or 32x ONLY. Buy better brand name data CDs, and you should have no problems. If you use my method as an example, and you still have problems, then you need to get a new CD burner for your computer. They are always cheaper at Staples or Office Depot. Hope **** works out for you : D
Nov 08, 2008 | Pioneer CDJ-800 Turntable
MediaForm 5908 CD burner buzzing
hmmm..is there a fan in that unit..check and see if it has some junk in it..
Oct 16, 2008 | MediaFORM CD 5908 (CD-5908-8DR) CD-RW...
Technics cd hi-fi
hi bobro, when burning the cds, make sure that you are burning it as an audio cd, as this player does not support mp3 formats, just normal audio cds... hope this helps!
Feb 11, 2007 | Technics SCEH790 CD Shelf System
MediaFORM CD 3706 Burner Logo
120 people viewed this question
Top MediaFORM Computers & Internet Experts
David Payne
David Payne
Are you a MediaFORM Computer and Internet Expert? Answer questions, earn points and help others
