Question about Microwave Ovens
Blowing Fuses I have a 1993 - 2000 Panasonic "the Genius" Microwave, and it has suddenly started blowing the fuse on the power supply card. I have replaced the 8A fuse with a 10A fuse, but that still blows. It was working fine up until yesterday, Please advise me as to what could be the problem, and how to rectify it. Regards Lyall Clifton
  • 76 Answers
Never put higher fuse then what is already there can cause a fire microwave are being made more disposable now either use warranty or buy a new one i am lucky if i get one to last a year before it starts acting up cheaper to buy new one then to have it repaired
Posted on Dec 03, 2008
I have a panasonic model nn-sd277 microwave. I changed the fuse and now it has power again. The fan and light all work. It trips my breaker and sometimes blows the fuse when you try to heat anything.
time to take it to an appliance repair shop for a quote
it is blowing fuses and tripping breakers because it has a serious short in the electrics
Jan 03, 2016 | Panasonic Microwave Ovens
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
Why does my Sharp Carousel convection microwave keep blowing fuses ?
I am wondering which fuse is blowing?
There are at least two fuses fitted internally and in the UK at least another fitted in the plug of the supply lead.
It isn't wise for an unqualified person to replace the internal fuses of a microwave even if it is switched off as there is a capacitor inside that is capable of storing a dangerous amount of energy.
The reasons why a fuse blows is either because there is a poor connection close by that is generating a lot of heat or the the fuse rating is incorrect or of the wrong type (quick-blow instead of slow-blow) or the appliance is consuming more current than it should be.
Microwave ovens have a fairly simple working principle and there aren't many things to go wrong. When things do start to go wrong or components become tired it is usually translated into a loss of efficiency that can be measured by how long it takes to boil a measured quantity of water, for instance.
Periodically timing a measured quantity of water to boiling point is a good way to monitor the performance of a microwave and when efficiency falls significantly take it to the service shop before something destroys itself and causes more damage.
In my limited experience the magnetron could be failing but the internals of a microwave should remain a mystery to the unqualified.
I hope this helps a little.
Jan 15, 2015 | Sharp Microwave Ovens
How do I find the fuses in Microwave
Mainly there are three/four fuses in Microwaves depend to maker.
First one to be checked it is on plug about 13A in cable out side microwave
Second one for power supply usually comes 10A located in terminal board of cable supply in side microwave if you follow the cable.
Third fuse i think about 5A for high voltage it located usually on wire connected between transformer and capacitor.
Fourth some Microwave have third one on the control board located behind switch panel.
now.
if the second fuse is blowing immediately after starting microwave that usually mean one or more of the following need to be replaced
1- diode
2- HV. capacitor
3- magnatiron
Which only can replaced by skill technicians
THANK YOU.
Oct 31, 2014 | Emerson MW8998B 0.9 Cu. Ft. Counter-Top...
Blowing fuse when opening microwave door
the microwave has a short in the power supply it can be the diode or the high voltage capacitor.have a tech check your microwave for repairs.good luck.
Mar 01, 2010 | Magic Chef MCD1611 Microwave Oven
I have a J HP60G 002 GE Microwave (older)keeps
If it blows the line fuse instantly when you push start.... it is either a shorted HV capacitor or shorted monitor switch.... most likely.
Sep 13, 2009 | Microwave Ovens
Our Panasonic Genius 1200w microwave stopped working all of a sudden. It's completely dead - even the front panel. Is it worth fixing?
It could be just the fuse and fixed for a couple bucks. Only way to know is open it up and check it. Eric
Sep 03, 2009 | Panasonic NN-H504WF Microwave Oven
Blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
May 21, 2009 | Emerson Black Microwave Oven
Keeps blowing fuses
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
You can order Panasonic parts from Tritronics here or by calling 866-779-5835, but if you don't find what you're looking for there, try here.
Nov 07, 2008 | Panasonic NN-H275 Microwave Oven
Microwave Ovens Logo
188 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
