Question about Dryers
Dryer won't spin
Hello FixYa,
I have a couple of friends that have an Amana brand electric dryer which has an unusually hard time spinning. I've looked at the belt and felt its tension around the drum. The belt doesn't seem loose. The dryer shakes a little, but nothing abnormal that you would expect from any other dryer new or used. When someone tries to spin it manually it is not easy. Any suggestions on fixing a dryer that gives heat but has trouble spinning if at all? Thank you.
Andrew
  • moslynch Dec 23, 2008
    i have the same problem the motor sounds like its running but it will not turn! The belt is still intact and occasionally the drum will move sightly. I have checked for obstruction and to see if it will move freely and it will. How do i get to the motor?
    Sergeant:
    Champion:
  • 324 Answers
Low voltage to the motor or a bad motor
Posted on Dec 03, 2008
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
Maytag dryer model 4000 ayw- spins but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 07, 2010 | Maytag Neptune MDE4000 Electric Dryer
Dryer spins and drum turns, but only cold air c...
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
My dryer works (spins, blows air) but it won't hea...
heatman101
May 19, 2010 | Dryers
Dryer spins but won't heat up
May 19, 2010 | LG DLE7177 Dryer
Dryer spins but does not dry brand is whirlpool model #LE7680XSW2 can you tell by model number what the capacity is. Thank you
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 11, 2010 | Whirlpool LER4634J Electric Dryer
Dryer will not heat. Just spins without igniting.
heatman101
May 11, 2010 | Kenmore 63942 Dryer
Power on but it won't spin.
Hello zurdo4ever
Welcome to Fixya
My name is Huum,
You said, power on , but it won't spin. hear a clicking noise in the motherboard.
Everything seems to work. except it won't spin.
The dryer was only spinning but not heating lately. need assistance
The clicking is a bad relay sound.
This is an electrical problem and it may be a need for a new cpb (Control panel Board) also.
time to get a tech in there to diagnose which problem you have and get you doing laundry again
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Dryer wont spin
If it heats but doesnt spin, most likely the belt. May not be broke though. May have fallen off. Let me know if you need more help.
Dec 16, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
150 people viewed this question
Top Dryers Experts
