Question about Carrier Heating & Cooling
I have a unit that is about 1.5 yrs old. That AC is OK. When the Heat pump kick in, a strange smell exists. I have had the dealer out for trouble shooting and the tech discovered that the UV light was out and had "leaked".I still have the odor, it is not a dead animal smell. The dealer also ran that mildew removing spray? I still have the "catch in your throat" odor. Can you help? The dealer doesn't want to deal with it, or has no idea what it could be.
  • 85 Answers
Good God, get a different Serv Tech, your smelling freon! Have the serv tech check for leaks, and if the problem does not get fixed you will have a narly bill on your hand, recharging your unit..
Posted on Dec 03, 2008
"I have a 13 year old 10 SEER Achiever RUUD UPKA-049JAZ heat pump when you turn the AC on the ouside unit makes surging sound about every 3 min after about 45 min the ac will kick on."
sounds like compressor is going bad .. first try a hard start kit.. have staved off replacing compressor many times.. may last a long time may last 1 day
also check charge
May 20, 2014 | Ruud Heating & Cooling
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
AC unit not kicking on...
You need a "Y" terminal. "Y" is pretty standard on every heat pump. It is the wire that will energize the compressor contactor at the outdoor unit, allowing the compressor and condensor fan to run.
Apr 03, 2010 | Heating & Cooling
Central heater kicks off and on constantly
It is a strong possibility the flame sensing electronic thermocouple has become contaminated. Buildup on it causes malfuctioning like you described. To remedy it you simple remove the flame sensor and clean it with steel wool. here is a video I found on line:
Furnace cycling frequently
Jan 06, 2010 | Mr. Heater Model MH12TS - Single Tank-top...
Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Jan 06, 2010 | Ruud UBHC Air Conditioner
Honeywell Wireless System THM5320R Wireless system and thermostat startup ok. The issue I am having is that; when the thermostat is in cooling mode and the unit starts the reversing valve is in the wrong...
how old is the existing system? i do ac in florida and usually if its not the wiring, an old systems rev. valve may stick. a firm tap on the valve may solve your problem.
Oct 28, 2009 | Heating & Cooling
Having a problem with my AC/Furnace. AC was working fine and was turned on for about 3 weeks. Thursday night it cooled off and we opened up until Saturday morning. On Saturday morning the AC would not turn...
I think your problem is poor usage of the device,i.e. overloading the system. try running better cables to your furnace and ac. The reason i am lead to believe that is. If you already hired a pro to come and fix it for you,and he/she could'nt then what else could it be? in my experience ac units use electricity like microwave ovens.and power tools
Sep 12, 2009 | Heating & Cooling
I am installing a Honeywell T841 onto existing RGYW wiring. The fan kicks on, but I notice the air conditioner is not running. Were one or more of these supposed to go on the W2 or B terminals? Thanks!
Need to have more numbers in model number to be sure There's about 30 T841 t'stats and some are1, 2, and 3 stage heat pump and some 1, 2, and 3stage AC.
If you have
R to transformer
G to fan relay
Y to contactor in outdoor unit
W to Gas valve
You have the thermostat wired right.
Depending on the T'stat B could be the common side of the transformer or 2nd stage heat.
W2 terminal are for 2nd stage heat
You need to put the thermostat on cool and lower the setting to bring on the cooling. Then go outside and see if you have power to the outdoor unit and 24 volts to the contactor coil.
Sep 06, 2009 | Honeywell Electronic Programmable...
First time we used the heat it smells.
Yes, It probably has electric secondary heat which will kick it about 4 deg under your set temp. It should smell like burned dust and go away within a days time. If it last longer or smells different you might want to have it investigated for a mouse nest or something.
Nov 06, 2007 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
125 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
