Question about O2 Xda II Smartphone
I got a signal the battery was low, and now after charging my phone doesn´t start again??
I was using my phone and I got the alert that my battery was too low and it was going to shut down. After the phone turn off, I charge the battery fully again and the phone is not turning on again? what can I do? Thks for your help. JLH
Maybe you must change your battery, it seemly your battery has not fully running well when it charged (broken).
Posted on Jul 02, 2007
    Problem Solver:
  • 7 Answers
Do a search on the site http://wiki.xda-developers.com/ Try the Keywords "Bricked"
Posted on Apr 26, 2007
My dell demension E521 is giving me a "alert system battery low" message. Any suggestions?
Check the batteries voltage and check to see if the battery is being supplied charge voltage when the computer is off. If both these are good then your low battery message is in error. No charge voltage would mean faulty charger and low battery voltage would mean faulty battery.
Dec 15, 2012 | Dell Dimension E521 PC Desktop
Phone won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 28, 2012 | Pantech Pursuit Cell Phone
My motoriola defy phone wont charge it has been at 0% charge all morning.
Hello and welcome to FixYa;
Take out battery, clean off the battery and gently clean off the terminals. Put battery back in and try to charge again with your charger. If this doesn't help;
Try another charger to the phone such as a car charger if you have one. If the battery still will not charge;
you may need to get another battery. I suggest you go into your local service provider first, have them use one of their spare batteries that fit into your phone model and see if the battery will start charging.
If it doesn't, you need to have your phone itself looked at instead of the battery.
Try these steps before you spend money on replacing parts needlessly.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
May 30, 2011 | Cell Phones
My Blackberry Bold 2 (9700) doesn't play any alerts when the battery level is low. I don't have the manual, so I can't tell if this is standard, or if there is anyway to fix this issue. Any help...
Hi this is normal for all BLACKBERRYS. What happens is the radio signal goes off. Charge your battery. Once you have a full charge on the phone take the battery out and rub the barcode where the sound strip is. Then putt the battery back in this should help solve that problem for you. Also don't let your bb get in the red to often it has an adverse affect on the phone. BB run on radio signals.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Nov 02, 2010 | RIM BlackBerry Bold 9700 Smartphone
My battery signal shows full and after sometime shows battery low
check if ur battery has swollen...this happens due to repetive over charging...d capacitors burn out...if tats d case...replace ur battery immediately..since d old 1 has chances of bursting...
if thats not d case thn try another battery,,,prob persists thn itz a s/w error goto a nokia care...they'll do it 4 free
Oct 28, 2009 | Nokia N73 Cellular Phone
Battery meter shows low battery even when the phone is charged
A simple reboot of the phone can resolve this problem. Failing that a complete resync with iTunes does the trick too.
Feb 23, 2009 | Apple iPhone Smartphone
V262 constantly beeps "low battery" alert
your battery might need to be changed. even if it has a full charger it might not be able to properly charge you phone.
try a new battery.
Mar 06, 2008 | Motorola Mobility V262
Vtech phones loosing connection to base
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B
3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
Mar 20, 2007 | Vtech i5808 Cordless Expansion Handset
O2 Xda II Smartphone Logo
181 people viewed this question
Top O2 Computers & Internet Experts
xxxxxx xxx
Jax Planet
Jax Planet
Hjalmer Lamminen
Hjalmer Lamminen
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
