Question about iLO DVDR05 DVD Recorder
When I burn a dvd on the ILO it works fine, but can not be viewed on any other dvd device.
I burn a dvd on the ILO it works fine, but can not be viewd on any other dvd player.
    Genius:
  • 1,074 Answers
Check the program you are using it might not be compatible to other system.
Posted on Feb 25, 2007
DVD wont burn with dvd maker gets to 99% then stops
HI THERE,
When was the last time it was working fine?
• Do you have any third party CDDVD burning software?
• Are you able to burn DVD's using windows explorer?
First I would suggest that you try burning using another DVD and check if it works.
Method 1
Try one or more of the following:
Verify that the DVD burner is connected properly to your computer and powered on, and that any necessary software drivers for the DVD burner are installed. You can check your hardware settings in the Device Manager by doing the following:
1. Click Start, and then click Control Panel.
2. Click Hardware and Sound.
3. Click Device Manager.
• Make sure that the videos you're trying to burn are not corrupted. To see whether the videos you want to burn is corrupted, try playing or viewing them using Windows Media Player. If the files don't play using the Player, Windows DVD Maker cannot burn them.
• Choose a slower burning speed for your DVD burner by doing the following:
1. Return to the Add pictures and video to the DVD page, and then click Options.
2. In the DVD burner speed box, select Medium or Slow.
Troubleshoot problems with creating a DVD-Video using Windows DVD Maker
http://windows.microsoft.com/en-us/windows-vista/Troubleshoot-problems-with-creating-a-DVD-Video-using-Windows-DVD-Maker
Change Windows DVD Maker DVD-Video settings
http://windows.microsoft.com/en-US/windows-vista/Change-Windows-DVD-Maker-DVD-Video-settings
Method 2
Check if you are able to burn DVD successfully using Windows Explorer.
Burn a CD or DVD
http://windows.microsoft.com/en-US/windows-vista/Burn-a-CD-or-DVD
Method 3
Check in the event viewer to know the cause of the DVD burning failure and post back with the details.
What information appears in event logs? (Event Viewer)
http://windows.microsoft.com/en-US/windows-vista/What-information-appears-in-event-logs-Event-Viewer
Hope this helps!
Halima S - Microsoft Support.
Visit our Microsoft Answers Feedback Forum and let us know what you think.
Aug 25, 2011 | Compaq Computers & Internet
Won't record on DVD+R discs.
These ilo R04 only record on 4x speed or slower, the new 8x or 16x won't work or will damage laser.The new variable speed discs work,these say 1x-16x.
Some brands of discs won't work in Ilo's.Try name brands disc like Sony, cheap brands often won't work.
Have you cleaned laser use commercial disc cleaner?Laser can be manually cleaned with a Qtip soaked in rubbing alcohol but this requires opening dvd burner.If you do this make sure electrical plug is pulled, laser will cause serious burns if you remove top while still plugged in.
Jul 27, 2009 | iLO DVDR04
TSSTcorp ts-H552B will not burn on any program.Have tried windows media, nero, powercd/dvd. Burned fine previously. It will play cd/dvd and rip fine but when I click burn nothing happens. Ran...
re-install nero. Or download a trial version of 1 click dvd. the problem will most likely be that ATAPI Or Couffin Drivers are not installed on your Computer. Also check your device is recognised In The Device Manager.
Failing this try the device on the secondary IDE or different SATA connector on your Motherboard.
Thankyou For Using Fixya.
Mike @ compurepair.
Jul 20, 2009 | Computers & Internet
Only view in black and white on my ilo DVD R04
I was having the same problem. My DVDR04 was working fine. And after about four months of not using it I desired to use it. Turned it on and everything was in black in white. After searching on line and e-mailing Ilo which I never got an answer. I finally tried using an RCA video (Yellow) cable on the line out video jacks, replacing the line out S-Video jack/cable and it worked fine back in color right away.
May 11, 2009 | iLO DVDR04
ILO DVDR05 RECORDER
I saw a device that hooks to the computer that allows you to input media from a player (VCR or DVD) to the computer but nothing that works the other way around. What is it you're trying to do?
Oct 22, 2008 | iLO DVDR05 DVD Recorder
Burning DVD-R playable on a stand-alone DVD Player using Nero Express 6
http://www.softpedia.com/get/CD-DVD-Tools/Data-CD-DVD-Burning/Nero-8.shtml
please go to the above site and download nero 8 which is more advance and enter the any of the keys
9K20-7839-0295-6KA4-5008-1KM3-8C64 (the one i recomend)
1K22-0867-0795-66M4-5308-3698-EE5M or
1K22-0867-0795-66M4-5251-9214-3AC7 or
1K22-0867-0795-66M4-5765-3212-7AA2 or
1K22-0867-0795-66M4-5085-3781-ACK0
good luck
Apr 20, 2008 | Ahead Software Nero Express 6.0 (NERO6OEM)...
PLEASE HELP ME
Hi Taranum,
Are you able to view CDs/DVDs that are already burned?
Ben
Mar 02, 2008 | LG DRN-8080-B for Dell Inspiron Series DVD...
Toshiba dvd burner problem
Try unistalling the dvd drive in device manager. Go to my computer click on view system information. Then click on hardware, then click on device manager find your dvd drive then right click and unistall a warning window will popup click ok. Once you unistall it restart the system and windows will find new device and reinstall the device driver. Then check if this fixes the problem. if this dosnt fix the problem try removing the dvd drive from the laptop and reinsert it. Sometimes the connection losses contact with the terminals.
Jan 19, 2008 | Toshiba Satellite A105 Notebook
Dvd player turns on and that's it
I have ILO dvd ro5/zu Burner walmart cheapy and I read Capacitors for power supply go bad and leak there are 2 (fuhjyyu 2200uf 10volt) also it runs very very hot so I put in an old computer fan to cool it down works great now, problems with clock flashing and humming noise while recording and playing back. It still has a little hum but other than that it works great 3-4 years old over 150 dvd's burned.
Sep 29, 2007 | iLO DVDR05 DVD Recorder
iLO DVDR05 DVD Recorder Logo
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
