Related Tags:
This problem should be removed because:
Problem with M-Audio M Audio Audio Buddy Microphone
How do you connect Audio Buddy to computer
So I just purchased the Audio Buddy Dual Mic Preamp/Direct Box and have no idea how to set it up. I have garage band on my mac and all I am looking to do at this point is record some guitar and vocals. What cables do I need to do this? Is there something beyond the audio buddy that I need in order to do this. Completely new to the home recording thing. Any suggestions would be much appreciated.
Solutions (1)
Best Solution
You probably connect the Audio Buddy via a USB or firewire cable. I use both types of audio interfaces. Your mac will sense which bus has audio. Go to System Preferences panel and select sound. Select input. You should see your Audio Buddy listed if it is connected properly. You can set levels from this panel and test the device by looking at the two level meters. Speak into the mic; the level meters should move from left to right.
Go to the output panel and chose your monitoring device. I prefer the built-in speakers, but you could also connect your monitor to the USB interface or even the Audio Buddy. If I need better quality monitoring I plug a mini cable into the earphone jack and use a desktop speaker. Don't try to use that headphone jack for anything but monitoring - the quality is not great.
If the Audio Buddy software requires that you select an input source, always use USB, never line or built-in mic.
Another way to capture audio from an Audio Buddy or similar device is to use Wiretap Studio Pro or Roxio CD Spin Doctor for audio capture. I use both.
Testimonial: "Thanks for the help. Works great!"
set up m-audio buddy dual mic preamp
Hi- I have a m-audio dual preamp; what is the best way to set up with 2 dynamic mics and a boss br1180 studio? Thanks! Albion
Main power led won't stay on.
Main power led won't stay on. Hi ! I connected my new M-Audio Audio Buddy to a 9V 1000 mAh AC power supply, and I pressed the power...
Hi, i am a singer/songwriter
Hi, i am a singer/songwriter and music student, not great with the tech side, but purchased a se electronic 2200 mic and the m-audio dual...
i have my m-audio dual
i have my m-audio dual mic preamp and a fast track inter face and i have no way of connecting the two.
Add Your Solution
I need to connect my
I need to connect my audo buddy to my mac with the imic. I have the Buddy plugged in. I have a Shure pg81 mic plugged...
What is the output level of the Audio Buddy -10 or
What is the output level of the Audio Buddy -10 or +4 ? Does it change when you use the DI input ?
Fix-O-Meter
1,344
1,344 people viewed this problem
- 1 person found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top M-Audio Microphone Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
The set-up sounds right. Audio Buddy will convert analog audio (your guitar) to digital audio your computer will accept. It is known as a digital/analog converter. The connection from the Audio Buddy to the computer should be a USB on both ends - a small USB on the Buddy end and a regular USB on the computer end.
The theory is that the headphone/microphone jacks on your computer go through cheap audio circuits so a pure USB digital input is better.
Why would you need an XLR connector? XLR connects balanced low-impedance audio sources, such as a microphone. Your guitar uses a 1/4 jack which is high impedance?
You would have to tell me what kind of recording you do in order for me to recommend a mic.
I use a ribbon mic for voice overs, Beyer hand-helds for vocals, and studio condenser mics for instrumentals. I feed these into a Behringer Eurorack mixer which provides phantom power where needed. That output goes into my USB audio converter, similar to your Audio Buddy.
If AUdio Buddy accepts XLR mics
The Audio Buddy we are talking about DOES NOT have a USB interface. My error.
It is a straight dual pre-amp/ I should have known because I have one sitting on top of a mixer.
You need to take your audio output from the Audio Buddy and input to a computer sound capture card or into a USB sound card. The advice is the same - be sure your computer is configured to accept the USB as its input source.
There are some issues with levels on the Audio Buddy; indeed, there is no headroom for excessive levels in capturing digital audio. Any levels higher than zero db will cause clipping and distortion. Set your audio input and output levels accordingly.
