I have just one CD read write drive. So how do I make a copy oof a video dvd
  • Geordieward Dec 03, 2008
    I have Roxio Creator 9 and do not want Nero
  • 104 Answers
To make a copy of DVD you will need DVD Writer and the software like Nero7 atleast. Check out the best price offered at ebay, they will cost you starting from $15 onwards
Posted on Dec 03, 2008
  • Vanbiak Thanga
    Vanbiak Thanga Dec 03, 2008
    Dude, I mean to say that no other option but purchase a DVD writer to make a copy of DVD!
Lg dvd ds9543cpm
When recording a dvd disk, you must close it out after the burn process has completed. That way it can be played on any other dvd player. Otherwise, the only drive that can read it is the dvd drive that created it.
Dec 03, 2013 | Computers & Internet
Hello felows ,, i have a XP lap top ,, my problem is that the cd drive reads dvd , cd -rom , audio cd ,, but when i put a dvd - raw , it wont read it ,, the cd is a hp deskjet 2050 j510 series to...
No all cds/dvd work in all cd/dvd drives. I suspect your drive cannot read that make of cd although anothers cd rom can. Try making a copy of the disk on someone elses pc and try that in yours and you will probably find it works. You could always copy the cd to a pen drive and install it on yours from that.
Jun 03, 2011 | Computers & Internet
I have a new laptop hpDV61340SA with windows 7 iam trying to load on a genuine copy of ms office 2003 and all that happens is the drive makes a noise as though it is trying to do something but nothing...
It means your Dvd-Drive can't read the contents of the Cd/Dvd media, try the media on another computer and check if it can be read or not, if it is so, then your option is to copy the files from the cd to the other Pc and save it to your flash drive, so that you can install it later, or if you can, replace the dvd/cd rom drive with another spare. Good luck.
Apr 11, 2010 | HP DVD DRIVE DVD Drive
Driver needed for TSST Corp CDDVDW TS-H653N SCSI CdRom Device please. DVD drive shown in My Computer, and MS says I have the correct driver for this device. But, it doesn't work.
If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive. If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement. Method 3: Try a different disc drive If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps: If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5. If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4. Method 4: Make sure that the disc is compatible with the drive Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive. A DVD disc is incompatible with a standard CD drive. A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs. A DVD disc is incompatible with a drive that does not have a DVD logo on the front. If the disc is compatible, go to method 5. If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement. Back to the top Method 5: Use Windows Update to check for updated drivers If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.com If these methods do not resolve your issue, try the advanced troubleshooting steps in this article. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help, or you might want to contact Support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus/ If methods 1 through 5 did not resolve the issue, you can follow these methods to try to isolate and resolve the problem. Method 1: Test the disc by using the command prompt to copy files Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive. To test the disc by using a command prompt to copy files, follow these steps: Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files. Click Start, and then click Run. Copy and paste (or type) cmd in the Open box, and then press ENTER. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:*.* HardDiskDrive:cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder. Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files. If you are asked whether cdtest specifies a file name or a directory name, press F. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER. If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement. To continue trying to isolate the problem and test the CD or DVD drive, go to method 2. Method 2: Test the CD or DVD drive in a "clean boot" state If the disc is readable and undamaged, there may be some hardware or software that is interfering with the CD or DVD drive. You can test this by inserting the disc into the drive after restarting your computer in a clean boot state. This helps you determine whether any hardware or software is interfering with the CD or DVD drive. To test this, follow these steps: Restart the computer in a clean boot state. Note For more information about how to start Windows with a minimal set of drivers, click the following article number to view the article in the Microsoft Knowledge Base: 310353 How to configure Windows XP to start in a "clean boot" state After the computer is restarted, exit all programs and applications that may be using the CD or DVD drive. First, right-click each icon in the notification area, and then click Exit. Note The notification area is located at the far right of the taskbar, near the clock. Some programs that are listed in the notification area do not have an Exitcommand. Therefore, you may have to click Quit, Close, or Disable, depending on the commands that are available for that program. Click Start, and then click Run. Copy and paste (or type) taskmgr in the Open box, and then press ENTER. Windows Task Manager opens. Click the Applications tab. If any programs appear in the Task list, click the name of the program to select it, and then click End Task. Repeat the previous step until the Task list is empty. Close Windows Task Manager. Reinsert the disc in the CD or DVD drive. If the CD or DVD drive can read the disc, there may be other programs preventing the drive from reading the disc. Go to method 3. If the CD or DVD drive still cannot read the disc, go to method 4. Or, if you are not specifically using a DVD drive, you may want to contact Support. For information about how to contact Support, go to the "Next Steps" section. Method 3: Change the CD or DVD drive configuration If there are programs that are preventing the drive from reading the disc, you can try to resolve this issue by configuring the drive to run in direct memory access (DMA) mode. DMA mode is a high performance mode for transferring data to and from devices. These include CD and DVD drives. To configure the CD or DVD drive to run in DMA mode, follow these steps: Configure the CD or DVD drive to run in DMA mode. For more information about how to switch your computer's disc drive controller to DMA mode, click the following article number to view the article in the Microsoft Knowledge Base: 310751 Device settings are hard to find in Windows XP Reinsert the disc in the CD or DVD drive. If the CD or DVD drive can read the disc, you are finished. If the CD or DVD drive still cannot read the disc, try to troubleshoot DVD components by using method 4. Or, if you are not specifically using a DVD drive, you may want to contact Support. For information about how to contact Support, go to the “Next Steps” section. Method 4: Troubleshoot DVD problems If the advanced troubleshooting methods 1 through 3 do not resolve the issue, and you have problems specifically with a DVD drive, follow these steps to try to isolate and resolve the problem. Prerequisite You must use a DVD drive with a DVD logo on the front, not a standard CD drive. Step 1: Unplug any cables that are connected Unplug any cables that are connected to the video outputs of the computer. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, you may have problems with the video hardware installed on your computer. Contact the manufacturer of the video hardware for support or for a replacement. If the DVD drive still cannot read the disc, go to step 2. Step 2: Update the DVD driver Contact the manufacturer of the DVD drive to obtain an updated driver for the DVD drive, and then follow the manufacturer's instructions to install the driver. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, the problem was caused by an outdated driver. You are finished. If the DVD drive still cannot read the disc, go to step 3. Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder Contact the manufacturer of the DVD drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer's instructions to install the decoder. Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, the problem was caused by an outdated DVD decoder. You are finished. If the DVD drive still cannot read the disc, make sure that the sound card in the computer is compatible with the DVD drive. To do this, contact the manufacturer of the sound card. Reinsert the disc in the DVD drive.
Feb 27, 2010 | Compaq Computers & Internet
When I want to copy a CD must I only record on a CD blank disc; i.e. not a DVD
It depends upon what type of data you want to copy onto a CD or DVD.
If you want to copy and play music in a CD player then it needs to be on a CD disc.
If you want to copy and play movie DVDs in a DVD player then it needs to be on a DVD disc.
If you want to backup data files then it can be on either CD or DVD discs (depending upon the amount of data to be stored on the disc - CD holds 700 Mb, single layer DVD holds 4.7 Gb, and dual layer DVD holds 8.5 Gb of data).
A DVD player can read both CDs and DVDs, but a CD player cannot read DVD discs.
Dec 30, 2009 | Dell Insprion 4F778 (4F779) DVD Drive
My disk drive is not working i am trying to down load a new program and when i put the disk in it will read it and then error appears
Hi saratrought, if Windows XP runs and you have read problems in CD/DVD drive try to read another disk, if any other disk work fine then you need to copy your CD/DVD info (or program) in another new disk.
Or just use Windows Explorer to try copy all data from CD/DVD disk to a New Folder in your Hard Drive and then from that location you can try to install your program, if your data don´t copy well then again i tell you that it´s your disk not your CD/DVD drive.
Sorry by bad english.
Oct 16, 2009 | Dell Inspiron 6000 Notebook
My DVD burner stopped working...but will still copy cd
Please try to clean your DVD Disk Drive using a CD or DVD Disk Cleaner to clean the laser lens of the DVD Disk Drive like dust, dirt and other small particles that causes the lens hard to read or eventually not read the laser lens. IF you don't have a Disk cleaner you can find it in any computer shop or video shop in your place.
Thanks
Aug 13, 2009 | Toshiba Satellite A135 Notebook
My laptop not use a pirated or copy dvd
While it's not legal to download, and burn DVD's illegally, if your rom has issues reading burned DVD / CD data, your drive may be faulty, or just needs to be blown out. Use a can of compressed air available from most office supply stores and blow any dust or debris out of the drive. Be careful not to touch the Lense, they are quite delacate.
If your drive still fails to read burned media, but does fine with normal media, the drive may not be able to read burned media at all, and you will need to replace it to do so.
May 30, 2009 | IBM ThinkPad T23 2647 Notebook
Model DRW 6S160PX06C
You cannot edit files *directly* on the CD/DVD. CD-RW and DVD-RW means you can "erase and re-burn" a cd or dvd, and reuse them like they were new.
You CAN however, just copy the files from the CD onto the hard drive and work from there. If you did that, sometimes files that are copied from a CD to the computer get copied with their "Read Only" flag set.
To undo that, in windows explorer, select the offending files that are on your HARD DRIVE, right click and go to Properties.
Uncheck "Read Only"
Click OK.
Now your files should be editable.
Again I emphasize that you cannot edit files directly on the CD or DVD. You can copy them to your computer, edit and change them as you see fit, and then re-burn the cd or dvd.
Jan 25, 2008 | NexxTech (DRW6S160PX) Burner
My DVD player no longer plays original dvd's - only copied dvd's
some times when you create DVD movies by high speed DVD writers, your data cannot be read by dvd player with high performance. it s due to speed mismatching. always write DVDs with Normal speed in order to use with DVD players. while in case oof PC-DVD -Rom it does not happens. it can read any high speed wriiten DVDs. DVD-Rom in PC are more precise than DVD players. Some times Weak DVD player Lens system can also mis read.
Dec 22, 2007 | Philips LX3000D System
Computers & Internet Logo
David Payne
David Payne
