Question about Hitachi 51SWX20B 51" Rear Projection Television
HDTV channels not working for my Hitachi 51swx20b projection TV. I have Comcast cable. Do I need an Hitachi HDTV tuner? and where can I get one?
I assume you are using a Comcast HD cable box ..... that's the only way you will be able to view HDTV. You do not need a Hitachi HDTV tuner.
Posted on Mar 16, 2009
  • 76 Answers
Yes from your cable company
Posted on Dec 03, 2008
My hitachi digital hdtv has always had cable hooked to it,and now i have no cable and i cant get the digital chanels to work with the antenna
The set will need a digital box to receive digital channels as it does not have a digital tuner in it--it is a very good set.
Nov 27, 2012 | Hitachi 43UWX10B 43" Rear Projection...
I can't get my Comcast cable channels to display on my Hitachi HDTV..how should I fix this?
A very well written question and I think you have provided your own answer.
this set uses a antenna switching assembly and they do fail. It could also be a bad tuner--note that the other owner got blu ray and such on it which are not via the coax fitting.
If your box has audio/video output jacks (like the blu ray) connect them to one of the rear audio/video inputs on rear of set and select that input on the set---box will then be used for channels but connection will not be via the coax but via that input.
If the box does not have those outputs get another--most providers do not charge for a box with those outputs on it.
If works you are just bypassing the tuner where your problem seems to be---those antenna networks are no longer available from Hitachi.
SD TECH
Jun 01, 2012 | Televison & Video
Do you have to add a converter box to receive free
You will need a converter box or a separate tuner. The TV has an NTSC (analog) tuner.
I hope this helps.
(the $40 boxes that are available are mostly SD. You should check the specs if you want a HD tuner.)
May 30, 2010 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 51SWX20B is this TV HD ready?
In answer to your question, you have an HD TV Monitor, which means that your television is capable of viewing high definition, but does not have an HD tuner. You will need a separate tuner or in the case of cable, a HD cable box. These are the only options that you have for viewing high definition channels.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs UP) If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 24, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Digital Channels??
Direct from the Hitachi website - "Integrated HDTV Tuners: Hitachi's new top-of-the-line XWX series features built-in ATSC terrestrial and cable HDTV tuners to provide integrated high resolution, high-definition signal decoding." You will need a seperate HDTV tuner if you do not have cable or satellite and want to watch off-air High Definition channels.
Apr 30, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Blue Ray Hookup
i have a ps3 hooked up to mine and the blue ray works very good connected using hdmi cable, converters work good also just purchased Hisense HDTV Tuner for mine
Dec 30, 2008 | Hitachi 51SWX20B 51" Rear Projection...
PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Nov 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Whine-no picture-audio only,1 channel
bring up the menu screen the tv and auto program the channels this lock out all un wanted and only allow the rf tuner input channel from the box if your using rf cable hook up,if not un plug the unit for 1 min. and try it again.
Dec 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
No signal on main tuner
can you connect comcast to another tv that should tell you if it's the tv tuner or cable company.
Nov 14, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hitachi 51SWX20B 51" Rear Projection Television Logo
120 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
