Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire Affinity Door Lock
I've had an 8000 series Frigidaire Affinity washing machine for about 6 months.  Just tonight I went to start a load and no luck.  When I push start the 1st time, the lights will all come on, I'll hear a click, then the door lock light goes out.  Trying to push start after that, nothing happens, no door lock, no click.  Any suggestions?  Could a clogged intake pipe or outflow pipe cause the locking mechanism to malfunction?  Would a lock repair be covered under my warranty?
  • ddelaughter Dec 03, 2008
    Would the drain be a problem though when there;s no water in there to begin with?  It's not filling because it's not locking
    President:
  • Frigidaire Master
  • 2,651 Answers
Under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Posted on Dec 03, 2008
  • Ron Coons
    Ron Coons Dec 03, 2008
    , umm probably not, was unclear in my interpretation of post, under a year def. call an auth servicer
The front door will not lock and pau is flashing on my frigidaire affinity front end loading washing machine and it will not start
You will need to replace your door lock mech.
On the bottom of the door seal lift the edge and locate the retainer spring and remove the spring then remove the door boot,unscrew the door lock disconnect the wirng and replace the door lock mech
Oct 07, 2011 | Frigidaire Affinity ATF7000E Front Load...
My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Door lock buzzing
sounds as if your door lock is broken and needs to be replaced.
Feb 06, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity atf7000es1 E41 code
check to see if the door stike is not broken on door if good and you have changed door lock asm you have a bad control board
Dec 11, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire affinity washer doesn't start
Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
Please reply or rate.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Front loading washer door lock
It has not been resolved yet. It has been worked on twice now. It has a new electric panel (not sure what it is really called other than the brain) and part of the motor has been replaced. Now apparently the heater core is not working. The tech told me the heater core probably went out which caused the other 2 issues. I suggest buying the extended warranty if it is ever offered to you. My washer is only 9 month.
Aug 29, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
751 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
