Question about Sharp 21" Multi System Stereo TV
DVD not working proper
I Hve a Sharp TV-VCR-DVD Combination
my DVD is not working proper Plays and Frezze say Acess denied.I Did not uesed the DVD resently, can you help me ?
Thanks Maggy
  • mbuschlendav Dec 17, 2008
    I have a Sharp TV VCR DVD Combination Model#
    27DV-CS10my DVD is not working proper.it start the Movie stpps and frezze,Access deied or Not Alowed. Clean the Head with a special CD.
    Have the same problem.Please help Maggy
    Genius:
  • 1,239 Answers
Hi
If its in a specific disk:
Try to clean it...
Is it possible your DVD disks are China bootlegs? If so, then you have disks that are bad as a result of bit rate down conversion problems.
If not:
Try cleaning the lens, all you need is a q-tip wet with alcohol. Just don't push to hard.
If this does not correct the problem, you may need to have your TV serviced
Posted on Dec 27, 2008
    Sergeant:
    Novelist:
  • 327 Answers
As you said you tried cleaning the lens it could also be the problem of motor which spins the disc internally that motor is either getting blocked or it is at its last stage so not running for long time just getting stopped.if dust or dirt is the problem cleaning will help but if faulty then replacement is necessary,
    Genius:
  • 1,199 Answers
This sound like you need to replace power supply! or drive motor!
Posted on Dec 17, 2008
    Master:
  • 505 Answers
When you are trying to play DVD and gets the region code, its a DVD problem wherein before you can play the DVD you need to change the region code.
Thanks
    Genius:
  • 1,550 Answers
The problem is due to
  • Defective motor and there is bad connections to motor.
  • Stripped gear or other mechanical damage.
  • Bad voltages from power supply.
Posted on Dec 09, 2008
  • Sharp Master
  • 19,396 Answers
Try first cleaning the lens using a dvd cleaner product, to ensure this is not a lens problem, provide the exact model number so that I can look for an eventual software update for the unit.
  • Sharp Master
  • 13,433 Answers
Try unpluging the dvd for 5 minutes and try again, also try a dvd lens cleaner, and reset the dvd player to default settings.
Try another DVD
I burned a movie on a +R DVD. It plays on my computer but not my Mintek DVD payer. Why is that?
computer disks are different then DVDs. you probably burned on DVR format. you can get a converter and make sure the file on the disk is AVI or, DVD
Sep 20, 2013 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Dec 18, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Sharp VT-51DV30 ....combo tv/vcr/dvd
unplug the unit and plug it back in see if it resets
Dec 02, 2007 | Sharp VT-G21 21 in. TV/VCR Combo
DVD'S PLAT IN BLACK&WHITE ONLY!!!
hey lindalu if you and i put our tv's together we might have one whole working tv/vcr/dvd combo that plays in color! Seriously though, i feel your pain. RCA i'm not impressed.
Feb 17, 2007 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Televison & Video Logo
29 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
