Back to:
Tags:
Gateway FPD 1730  17 in. Flat Panel LCD Monitor
Broken Monitor (by 2 users)
posted by Roeder on Feb 02, 2007
I would appreciate an explanation for what might have happened to this monitor. The user reported a fizzing, cracking sound, the image on the screen became very distorted, and a crack was visible on the screen. Then, the monitor quick working altogether. What might have happened to this monitor, and is this an unusual occurance? Is it repairable, or would we need to send it in to be replaced under our warranty agreement?
I would appreciate any information you can provide! Thanks!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by taildog99, posted on Nov 23, 2007
Hey Roeder,
I have this same issue. Do you still have your broken monitor? If so, I may want to take it off your hands.
What do you think?
Solution #1
posted on Jul 08, 2008
Not Rated (0)
easyq
Rank:Guru Guru
Rating: 86%, 41 votes
Guru's tip is very good. Only 1 small issue left out, is the monitor standing free and not near any heating devices or heat generating devices or in a very moisty area? these are things to bear in mind when placing sensitive electronics or better, all electronics as such devices or areas can cause the crack or the described failure of a component.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Broken Monitor:
I don't want to Accept this solution
Solution #2
posted on Feb 02, 2007
Not Rated (0)
tomj23
Rank:Guru Guru
Rating: 86%, 1570 votes
Hi Roeder,
I have never heard of an LCD screen cracking from anything other than physical force, this is a first for me. It is possible since there is high voltage power in there for the backlight. In light of the sound I suspect a component failed, generated lots of heat real quick and caused the crack/failure.
This is really unusual and you might try calling Gateway to see if they will replace it, especially if it is one year or less old. I would resist all temptation to open the LCD till you call Gateway. If they will replace it they won?t be happy to find you opened the case.
Let us know how it works out and please don?t forget to rate this post.
Thank You!
Can you Help with these Monitors problems?
Monitors
Screen flickers and flashes. Then settles down for a few...
Monitors
hi dear, my computer works fine but...
Gateway FPD 1730 (Platinum) 17 in. Flat...
on the right side of my computer from top to bottom is...
i could use the inverter but if your trashing the whole...
If you are trashing your monitor before doing so toss me...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
