Most times i switch my lorg c-26 electric piano on, it does not make any sound at all!
SOURCE: split two hands for two different sounds
The SP200 does not have any built in ability to split the keyboard between high and low. My guess is that you were seeing someone using this keyboard as a midi controller for a sampler (or sample player) and they had assigned various samples to keys or key ranges. This can be done using Reason fairly easily. The setup would be in the sampler you use however and not the keyboard.
Hope this helps.
bd.
SOURCE: korg c-56 struck by lightning.
if your keyboard has been affected by a lightning strike then every semicondutor ( diode transistor i/c ) will be blown ...I know most components are on the mother board but not all ...I reckon cheaper to buy a new one ...sorry
SOURCE: Need help connecting Korg C-303 (Concert Piano)
Assuming the C-303 has a MIDI out, connect a MIDI cable from the MIDI output of the C-303 to the MIDI input of the symphony module.
Connect two audio cables (mono 1/4 inch) from the symphony module to a suitable audio amplification system OR possibly into auxilary audio input jacks of the C-303, if they exist.
I have a Symphony module but not the piano you have and I have mine connected to a Yamaha organ.
SOURCE: Hello i have a korg pa 800 just a while ago
If this is not a low power supply problem, you might try circuit cooler to isolate the bad part.
Beyond the power supply I would recommend taking this to a shop for repair ONCE you have tried a factory reset.
Use this site for downloads:
http://www.korgpa.com/pa_root/en/products/pa800_soft.html
SOURCE: No sound will come out
See if the sound is present at the headphone jack by plugging in headphones. This is the start of testing.
