Question about Gateway 7508GX Notebook
I can not open gateway 7508gx, all screw removed and harddrive screw to
I am trying to get at hard drive on Gateway 504Gr. I cannot get the side off --- the 'screws' if that is what they are are inverted and too tiny to get any screwdriver in. this tiny things are hold
Margaret,
As you face the front of the Gateway 504gr desktop computer, the Left side panel removes.
Looking at the BACK there are two Thumbscrews to remove.
These are located along the edge of the Side Panel itself;
One located near the Top, and one located near the Bottom.
The thumbscrews may just loosen, and not come out. (Each thumbscrew is supposed to be held on by a small circular clip)
Once they are loosened all the way pull back on the Side Panel using the indented fingergrip molded into the side panel.
Pull back, and then when the panel stops, ease the side panel out.
The Side Panel has 'hooks' made into it, that match up into corresponding slots in the metal computer case frame.
This is why the side panel only slides back so far, then is eased to the outside.
With the Side Panel removed you will note there is a metal frame around the Harddrive. (Harddrive Caddy is the name of the rectangular metal frame)
Remove the power cable to the harddrive, and the data cable.
Remove the one or two Philips head screws which fasten the harddrive to the harddrive caddy.
Slide the harddrive back and remove.
(WATCH your fingers! There are very sharp metal edges present!)
Have any additional questions concerning this please post back in a Comment.
Regards,
joecoolvette
Dec 15, 2014 | Gateway Computers & Internet
Describe your gateway 7508gx notebook
I beleive the part they have replaced is called the inverter. I found a link here with pictures how to do that.
http://www.instructables.com/id/How-to-Take-Apart-a-Laptop/
hope this helps. you need screw drivers and patience
Jul 29, 2009 | Computers & Internet
Gateway DS PROFILE 4 XL need to remove hard drive
To remove the harddrive from your desktop computer
1.unplug
2.open the pc case
3.disconnect ide harddrive cable from the hard drive
4.disconnect power cable from harddrive
5.unscrew the hard drive
6. take the hard drive out.,
Nov 01, 2008 | Computers & Internet
The power button is stuck in OFF position. How do you disassemble the laptop to fix it?
i suggest you do that. this takes time, patience, the right tools, and a perfect memory for where parts come from
Oct 20, 2008 | Gateway 7508GX Notebook
Replace hard drive on Gateway laptop
get a New 2.5'' laptop hardrive, and follow the steps: - Turn off the Laptop - Take off the Power Supply - Remove the Battery - Remove the Screw from the Harddrive cover plate - Once cover removed,romove the other (2) screws that hold the harddrive - Slide the Harddrive toward the Screw Hole - Lift the Connection End. - Slide the New Harddrive towards the connection end, Put back the Screws & cover plate - install a new copy of Operating System.
hope this is helpful 'suraj'
Oct 10, 2008 | Computers & Internet
How do you replace a harddrive
power off the computer and remove the power cord from the power supply
remove the both side covers off the computer
inside you will see the harddrive towards the front probably under the cd rom or a drive take off the cords attached to it i recomend labeling them for identififcation purposes then get a phillips screwdriver and remove the screws that are holding the harddrive in place ow just slide the harddrive out and install the new one put all the screws back and the cables back the way they came off then put the side covers onn and you are done
Aug 27, 2008 | Gateway Computers & Internet
About my laptop
http://www.fixya.com/ThreadView.aspx?thid=634141&prdid=485713
May 30, 2008 | Gateway 7508GX Notebook
Taking my laptop apart
On which part of your laptop, you get stuck in openiing it..?
Gateway 7510 DVD PLAYER
Look for an external swicth, to pull the drive out. If your laptop dont have it remove the bottom screws, the remove the
keyboard, finally you can push the cd drive out of the computer
Let me know if this post help you.
Dec 20, 2007 | Gateway 7508GX Notebook
Gateway 7508GX Notebook Logo
88 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
