Question about RCA MM36100 36" TV
This tv does have a digital tuner, yes? It will see analog channels like 18 or 41 but not channels 5.1 or 5.2. Is there an aswer? thanks
4 Suggested Answers
SOURCE:
Shuttle83
  • 1139 Answers
SOURCE: Tuner Problems
OK the tuner may be causing these problems, however first I would like you to go to your menu and set the RF pickup to antenna (This will allow analog channels) then come out of the memu and select a channel in the analog range channel 4, 7, or 9 try to tune in these channels. If this fails then you may have tuner problems the only way to be sure is to use a RF signal generator to send RF through the tuner and see if the video and audio being carried on that signal comes through. Sometimes the Internet connect gets messed up when the TV does not have the proper RF filters this may be your case. Try this use a Cable tv set top box and just set your TV to channel 3 for cable. This should Isolate the TV from the Internet cable modem and provide the signal needed by the TV.
Posted on Sep 19, 2007
  • 6 Answers
SOURCE: we bought a 20" analog/digital
This could be caused by two different issues.
  • Digital signal reception is bad. The digital signal must be locked in, digital signal reception is either on or off (not like analog signal reception where you can receive a low signal and a fuzzy picture). You may need to adjust you antenna direction and height or obstructions around your antenna, reference the web site for your specific location (address) for antenna compass headings. http://www.antennaweb.org/aw/Address.aspx
  • Television is faulty, digital receiver is bad. Your new television has two receivers, an analog receiver and a digital receiver. A simple power surge will knock out your digital receiver. Make sure you have a quality surge suppressor connected to the television power and the antenna is properly grounded. Return the television for a replacement and purchase a quality surge suppressor.
You must add a quality surge suppressor to your digital television! http://ezinearticles.com/?Power-Protection-in-the-Home-Theater---Use-of-Surge-Suppressors-to-Guard-Expensive-Electronic-Gear&id=41318
Good luck.
Posted on Jan 03, 2009
  • 48 Answers
SOURCE: rca 14" truflat
really depends on the model. I've got a 2005 26" RCA truflat that has both digital and analog ota tuners--I can pick up off of rabbit ears OTA broadcasts, as well as via coax cable (cox cable) any of the unencrypted clear digital channels (QAM). Just can't handle the encrypted channels. If there are multiple coax inputs, check their labels--if labeled digital, likely that you've got a QAM digital tuner. Also, in the menuing system, channel scan--does it identify signal type as selectable digital/analog?
The surefire, get the model number, goto RCA.com website, download the user manual.
Posted on Mar 14, 2009
What features does a apex tv gt3215 have?
GENERAL
  • TV typeCRT TV
  • Screen size
    32 in
  • Power Consumption Operational
    150 Watt
  • Timer Functions
    Sleep, wake
  • Video Interface
    Composite, S-Video
  • Manufacturer
    Apex Digital, Inc.
FEATURES
  • TV features
    auto volume adjustment
VIDEO
  • Technology
    CRT
  • Aspect ratio
    4:3
TV TUNER
  • TV tuner presence
    Yes
  • Analog TV tuner
    NTSC
  • Reception System
    NTSC-M
  • Secondary Audio Programme (SAP)
    Yes
  • Secondary Audio Program (SAP)
    Yes
  • Channel Coverage
    VHF:2-13, UHF:14-69, Cable:1-125
  • Stereo Reception System
    MTS
AUDIO
  • Speaker(s)
    2 x main channel speaker - built-in - 5 Watt
  • Output Power / Total
    10 Watt
  • Audio Controls
    sound mode
CONNECTIVITY
  • Video interface
    composite
REMOTE CONTROL
  • Type
    universal remote control
  • Supported Devices
    DVD player
CONVENIENCE
  • Closed Caption Capability
    Yes
  • Parental Channel Lock
    Yes
  • V-Chip Control
    Yes
  • Menu language
    Spanish
MANUFACTURER WARRANTY
  • Service & support
    1 year warranty
POWER
  • Nominal Voltage
    AC 120 V
  • Power consumption operational
    150 Watt
DIMENSIONS & WEIGHT
  • Weight
    156.5 lbs
DIMENSIONS & WEIGHT (SHIPPING)
  • Width
    38.7 in
  • Depth
    29.2 in
  • Height
    30.5 in
  • Width (Shipping)
    38.7 in
GENERAL
  • Manufacturer
    Apex Digital, Inc.
Mar 08, 2014 | Televison & Video
How to switch from analog to digital
The LED LCD TV's came out in 2009. It already has a built in digital HD tuner.
Allen wants to know how to switch the TV between the built in analog tuner and built in digital tuner.
Switching between the two tuners is done by means of the "TV mode" switch on the remote control.
You will NOT be able to select analog channels if have NOT done analog tunning.
If you need to do a retuning then hit the "menu" button select "setup" then "plug and play" enter the default pin number 0000. When you are selecting the channel source to memorize make sure you select "digital and analog". This will then cause the TV to tune and memorize both the analog and digital channels.
For details refer to page 8 of the user manual.
Feb 24, 2014 | Computers & Internet
I would like to know if this TV model is digital raedy.It has a MFG. date as 2000 I want to take it on a trip if it is digital ready. Thank you Thom
If the tv it is flat and tv LCD screen design than it is digital ready.It well be able to pickup free DTV air broadcasting from tv channels stations.If tv it have a big back and bulky design like it have CRT-tv tube.It well not pickup tv broadcasting in tv digital channels,all tv channels went digital on 2006.
Jun 30, 2011 | Televison & Video
I have a nspdp42 plasma and i cant affort cable and want free tv. is there a analog to digital converter in the unit already? the model # is 801rmd2237770 Thank you
The Insignia NS-PDP42 Plasma HDTV has a built in ATSC/NTSC/QAM tuner.
In short, yes, it does have a digital converter built in, but you will need a antenna capable of receiving digital broadcasts. You can find these at Walmart for $15 to $60.
Mar 05, 2011 | Insignia 42" Flat-Panel Plasma HDTV
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
No digital channels
This TV is not able to understand digital channels because its tuner is not able to find that band, it works only in analog channels. To be able to get HD channels is needed a decoder box that has digital tuner build in. for a tv to understand HD Channels with analog tuner is to us to try to speak at the same time different languages.
Mar 16, 2009 | RCA HD52W56 52" Rear Projection HDTV
Just a question:
Hi, Yes you are in Luck! This model has an ATSC tuner which means it will receive digital channels just fine. Hope this Fixsya!
Feb 24, 2009 | Orion STV2763 27" TV
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Tuner
Yes, you will need the converter box in order to view the digital channels if you are receiving off the air signals but if you have cable or satellite TV, you might not needed. You can click here to know the specs of your TV, it has an analog tuner and not a digital.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
RCA MM36100 36" TV Logo
18 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
