When I load a dvd it spins and then says no valid discWhen I load a dvd it spins and then says no valid disc
AnonymousFeb 04, 2009
Disc spins & saids no valid discDisc spins & saids no valid disc
AnonymousMar 27, 2014
when i put the dvd in the player it says loading then a short time later it will say no disc when there is a disc in therewhen i put the dvd in the player it says loading then a short time later it will say no disc when there is a disc in there
You can't post conmments that contain an email address.
Hello The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
pls. check regnel code seting .
use remote cantrol on setup menu open and selact regnal code set Adealt . or all regnel code after then use disc is play caractly
if not then problum is inside your disc player .
Use. lance clenar disc and clenig your disc player lance.
This happened to me several times, Eventually i gave up. One day though i tried it again and it worked. You should probabaly wait a month or two and see what happens
Paul Sim, coby portable dvd player model TF DVD7005 keeps coming up with an error message that says NO DISC regardless of whatever disc you put in, the player comes up with the message LOADING on the screen and then stops after a little will and comes up with the NO DISC message
Try cleaning the lens. A CD cleaner for PC CD/DVD will also work with DVD players. If problem is not corrected, you may need to seek the services of a qualified professional.
Good luck and kind regards.
Check to see if the disc is spinning. You can do this by one of two ways either
a:) Listen for the disc to spin after inserting it or
b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
that noise sounds like the focus is trying to see the disc as it has to focus to see or register there's a disc. Maybe the turntable slipped down a little or there's dirt or film on the lens. Good luck
