Question about Palm Treo 755p Smartphone
Palm Treo 700p keeps crashing
This is the 2 phone that I have had and everytime out of the blue the phone crashes and I don't get a chance to back it up, because it happens all of a sudden. Just finished making a call and look up 5 minutes later and it was flashing the start-up screen. It just keep cutting on and off. It continues to show the start-up screen. Both times that it has crashed I have had to do a hard reset and lost all my contact information. Is there anyway to fix this problem without doing a hard reset. This is really starting to get on my nerves.
  • Anonymous Jan 16, 2009
    my acces powered screen shows up then turns off and comes right back up hard reset will not work help me
  • Anonymous Jan 28, 2009
    My treo
    Sergeant:
    Champion:
  • 258 Answers
Next time you have to hard reset, and before you sync, rename the user backup folder. This will stop thrid party apps from installing.the folder is C:\Program Files\Palm\%userID\Backup
Rename it something like _back or backu_
You'll have to reinstall 2rd party apps, and I suggest you do this one at a time.
But I also recommend you get and use NVBackup. It's a FREE easy, configurable backup program that can be set to backup the ENTIRE system to the card at regular intervals [mine is 3am every day.] then you can restore in minutes without even connecting to a PC. google it... or get it here...
http://mytreo.net/downloads/nv-backup,1090.html
Posted on Dec 07, 2008
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
I replaced the screen in my palm treo 700p and now the phone works but the screen wont come on.... what do i do?
Can you hear it ring when u try to call ur number using a different phone? If yes, maybe it isn't aligned properly or check the connector.
If no, the software is crashed, it needs a software reflash/reprogram
Dec 15, 2009 | Palm Treo 700p Smartphone
My palm treo 755p
Dhorner64 is incorrect. Your phone is not fried if you are in a restart loop. You need to do a "warm reset" which will not erase data. It is the equivalent of doing a safe boot in Windows. Remove the battery from your 755p, then put it back while holding the up button on the 5-way. Hold the up button as the phone starts. I had to do this frequently, then run the DataViz Tech app, which is available free from DataViz, to fix their prefs file, which was the source of my crashes. The problem was solved by upgrading to Docs2go v11. I was reluctant to pay to upgrade a crashing app, but the upgrade ended the frequent crashes. I have not had a couple resets since upgrading Docs2go, and no reset loops.
Nov 23, 2008 | Palm Treo 755p Smartphone
PALM TREO 700P PROBLEM HELP!!!
While holding the power button and re-inserting the battery will prompt you to choose whether or not to erase all data. If you choose "yes" the phone will reset to factory defaults. This should be done as a last resort, but at this point the phone is not functioning at all. Once restored, you can sync it with your pc or laptop and it will import all of your contacts, notes, favorites, and calenders just as it did before. In the future you may want to think about using an SD card for documents or other important information that could be lost in the event you have to reset again.
Good Luck
Jun 30, 2008 | Palm Treo 650 Handheld
Palm Treo 700
check palm.com there might be an audio patch available for your device.
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=79,E=0000000000858319401,K=4192,Sxi=11,Question=obj(43852):obj(44018)
supprot site for your palm device
Dec 24, 2007 | Palm Treo 700p Smartphone
Bluetooth pairing with Lexus
Try using the following code: 0000 on the Palm Treo and your car's device. It worked for my BMW 328i
Nov 11, 2007 | Palm Treo 700p Smartphone
Nonworking keys on Treo 700p
make sure first of all that there arent any screws missing or loose in the back by removing the battery cover....thats can cause the keypad buttons to not have a good connection to circuit board... if thats ok then you can use a toothbrush and some alcohol (denatured alcohol if possible) to rub and clean the keypad. If all that fails, I know that Sprint offers repair for their phones.
Palm Treo 755p Smartphone Logo
89 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
