Question about Kenmore Refrigerators
Reset light staying on how do turn it off
After i charge filter need to reset light
  • bklyn1008 Dec 03, 2008
    tk u/ nice pic
  • Kenmore Master
  • 2,651 Answers
Hold down the betton(s) for 3-5 secs to reset
Posted on Dec 03, 2008
LG filter light stays on
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. Air Conditioning Boca Raton
Jun 12, 2016 | LG Heating & Cooling
Replace filters light stays on even after changing wicks. How do I turn it off?
You didn't specify what brand/model of humidifier your using, but you can still try a couple of things. (Try the most logical first).
Try turning the control knob to the "test/reset" position & wait until the humidifier "on" light blinks; indicating it is resetting the timer & the change filter lamp will turn off.
I believe that you will need to do this while the furnace is calling for heat, if it isn't, turn up the thermostat and try it.
Jan 05, 2016 | Humidifiers
I have an american style hotpoint fridge freezer MSZ902DF which has had a water filter change as blue light on but despite following process the light has now turned to orange. Can anyone advise what we...
Refrigerator - Water Filter Indicator Light Will Not Shut Off After you change the filter the RESET WATER FILTER must be pressed and held until the red light goes off.
Note: If you do not hold the pad in, the light will stay on. Also, if you hold the pad in for a long period of time, the light will go off and then come back on.
If this does not turn the light off, having it checked by a service technician is recommended
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
Mar 04, 2015 | Hotpoint Refrigerators
Check engine light solid
Most of the newer vehicles have a senser that will turn the check engine light on, even when it's time to change the oil. After they change it, they reset the check engine light to turn it off. It could be something as simple as that or even an air filter needing to be changed. The dealer can tell you how to reset that light to turn it off. Good luck!
Nov 14, 2013 | 2003 Chevrolet Silverado 1500
Have a red light on in front - looks like something needs serviced. I rinsed the filters that pull out and light stays on. Might be a filter further in the unit or something might need to be reset??? ...
To the left of the little red light is the reset button. It's disguised as another light that isn't on. :) Press and hold it for about 10 seconds and the red light will turn off.
Mar 03, 2010 | Honeywell QuietClean HFD-110 Air Purifier
Red light stays on after changing the water filter and running about 2 gallons through it
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Oil light stays on
You need to put the key on and push the gas pedal to the floor three times within five second to reset the oil life light.Some g.m.'s have a reset buttom in the fuse panel that needs to be pushed first and some don't.Check the owners manual under change oil for your specific year car.
Oct 21, 2009 | 2003 Chevrolet Impala
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
I have a Cyber DSC F-828 and it will not turn on indacator light flashes after charging and reseting but wiil not stay on. Battery has a full charge. Help thanks
i have a Cyber DSC F-828 and it will not turn on indacator light flashes after charging and reseting but wiil not stay on. Battery has a full charge. Help thanks
Dec 19, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
May 24, 2008 | Honeywell HHT-090 Air Purifier
Refrigerators Logo
88 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
