Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Access light is blinking.
Plz help guys.
I bought a new Nikon D40 last week. Today some of my friends statred using it.
Now if i press any button on the camera access light is blinking and I am unable to take pictures.
Plz help me.
  • Anonymous Dec 08, 2008
    i have had my nikon d40 now for a few months and like other people am experiencing the camera locking up and refusing to take pictures. i tried taking the battery out, turned off then turned on the camera but this doesn't seem to work then suddenly it will start working again when you think it won't. very odd! i will try follow the instructions from the suggestions here. i hope this problem doesn't persist.
We have a D40X and had a similar problem!
What I did was pretty much reset everything! Take the batteries out, reset to factory settings and reinsert media card. I'm sure the other users did not do permanent damage and it may just be attempting to process corrupt data.
Hope you are taking pix again SOON!
Posted on Dec 03, 2008
Low toner warning light always blinking
maybe the toner t1810c is not original...try this code turn off the machine then press 0 and 2 at the same time then a value of 3 digit will appper just press start button...dont turn off the power other wise this toner warning will show again...repeat this procedure the next time u off then on the machine...hope this can help...
Apr 05, 2013 | Office Equipment & Supplies
Autofocus problem
Does this problem still exist when you have the shutter pressed halfway down?
Regards,
Worldvet
Jun 15, 2008 | Nikon D40x Digital Camera
Where's the shooting information of d80 in the larger screen?
The Shooting Information screen was introduced with the D40. The older D80 does not have it. Instead it shows almost all of the information in the control panel and/or viewfinder, though you have to delve into the menus for some of it.
Most of the settings you could change via the Shooting Info screen on the D40, you can change by pressing the appropriate button and turning one of the command dials.
The D40 was intended as an introductory dSLR, doing more handholding for new photographers, putting things into visual, menu-driven screens. The D80 was intended as a midlevel camera, allowing faster operation using more buttons. It does less handholding, but once you learn where the controls are, it actually is faster to use. (Okay, that was based on my personal experience, since I've used both.)
May 27, 2010 | Nikon D80 Digital Camera with 18-135mm...
Code for Sky+ remote to work with Toshiba TV AV635DB
Hi there. I have just bought the same television today and I have just found that the remote code 0156 does actually work. The mistake i initially made was not pressing the TV BUTTON after I had held in the SELECT and RED Buttons together, making the light blink twice. So here's what I did:
1. Press the TV button
2. Hold in the Select and Red Button until the red light flashes twice
3. Press the TV button again
4. Enter the code 0156 (The Red light will blink Twice again)
5. Test the controller - Try to change the volume
6. If it works, press SELECT one last time to save the settings.
Hope this helps.
apnit
Jan 04, 2010 | Televison & Video
D40 "Error: press shutter release button again." Nothing happens.
If you can dare servicing youself You can open bottom cover of and turn a little red wheel manually. try pressing the release button now and will start working. If you have this problem re-accuring, then get it checked wih professional.
Dec 19, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Is a Quantaray QF30 compatible for a Nikon D40 camera?
I bought this flash on craigs list today for about 30 dollars. I did research and as long as the flash you buy is a nikon HOT SHOE mount it will work. (Look on the bottom of the flash) it will say Nikon i-ttl. I am using it on my D40.
May 12, 2009 | Quantaray QF30 for Nikon Flash
Tamron teleconverter 2x AFs compatibility.
When using a TC, as the perceived focal length increases and the aperture falls off, AF struggles to work except in very bright light.
Jun 09, 2017 | Tamron Autofocus 2x Teleconverter Lens for...
Frustrated female with a stupid camera
hi ,
i am a d40 user myself and i dont have anything but praises for the little guy. check out this link from nikon guru kenrockwell . i think his userguide is even better than the nikon manual itself :)
http://www.kenrockwell.com/nikon/d40/users-guide/index.htm
Oct 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 flash won't fire
If lightning bolt icon is blinking in viewfinder, flash is not ready. Either flash isnt popped up all the way or flash strobe tube is bad.
May 02, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
70 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
