Question about Lexmark Computers & Internet
Have new computer. Used CD for printer to install. Would only print ist page. If additional sheets required, would not print. Printer: Lexmark 2400. Computer: HP with Windows Vista. What is needed to get printer to work Properly?
  • oldisp429 Dec 06, 2008
    Excellant aid, thanks.
  • 837 Answers
Goto lexmark.com
drivers & downloads
driver finder
enter 'x2450' for model
and download the xp driver and install
I'd appreciate the 'fixya' feedback too
Posted on Dec 03, 2008
Samsung clp-365w crashes computer when trying to print
Uninstall the printer and reinstall it using the new driver. After removing the old driver and installing the new one, scan your computer with RadarSync so that you will know which drivers need some updating.
David
Apr 09, 2013 | Samsung CLP-365W Laser Printer - Color...
Printer will not print. Removed both print cartrages, replaced black only due to cost/need. Printer will still not print (sheet comes thru blank)
Make sure both color and black cartridges are installed in the printer. The printer requires all cartridges to have ink in them to continue printing.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X4270 All-In-One InkJet Printer
Lexmark z2400 will not print, the comuter says document is pending. All connections are correct. Do I have to uninstall the printer, and reinstall with the CD? I rebooted the printer, and nothing. It is...
I am assuming you have it connected via USB to your computer. If you have an additional USB port on your computer then try powering off the printer, attach the USB connection to a new USB port, go to the Control Panel (Start, Settings Control Panel), go to Administrative Tools, go to Services, scroll down to Printer Spool, stop the service, start the service, and power on printer. Try to print a test page. If it fails, power off the printer and delete the print driver. Reinstall the driver using the CD.
Aug 30, 2010 | Lexmark Office Equipment & Supplies
Printer cannot find application list for Scanner
Good day!
The scan software might not be installed properly in the computer. Try to run the installation cd in your computer again. If you have already used the installation cd in the computer, running it again should give you three options - Install a printer, Update/Upgrade or Install additional softwares. Choose Install Additional Softwares. In
the next page, place a check mark in Abby FineReader OCR software. Continue and finish the installation. Also, check your
firewall and make sure to allow all Lexmark communications to go
through. Try scanning again. Hope this helps.
Mar 16, 2010 | Lexmark X4550 Multifunction Wireless Color...
My printer is not printing Lexmark 5400 series
DO NOT use the Windows 7 Lexmark Driver for the 5400 series on the model X5470 all-in-one! I just assembled a new Win 7 computer and could not get the obvious Win7 64 bit driver to work. I called Lexmark tech support several times, and the third time they conceded that you can't use it. You have to use THIS ONE!
CJS5400en.exe (just for the X5400). Make sure you UNINSTALL COMPLETELY any previous Lexmark printer driver and check the hard drive for any vestiges of previous installations BEFORE installing the new driver...and do NOT use the 'cleaning utility' file that is on the Lexmark site for Win 7 - to clean all bits of former installations first...According to tech support, it doesn't work on Win 7!! I told the tech person that the driver site needs to be more specific on which models use which drivers...he agreed.
Feb 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
Printer won't print, it says it is but nothing happens!
go to the following link, download the 2400 printer driver.
http://www.xpvistaworld.com/lexmark_2400_series_1234.htm
there is no grantee that the driver will work with WIndows Xp or Vista. the 2400 printer is made for Windows 2000 or earlier version OS.
good luck
Jan 05, 2009 | Lexmark Office Equipment & Supplies
Lexmark Imaging Studio
I had same problem on windows vista.
Went to c:\drivers\printer\4300\applications\setup.exe
and Yippee it worked!
Mar 30, 2008 | Lexmark P4350 All-In-One InkJet Printer
CODE 38 mEMORY FULL
A laser prints a whole page at a time, some pictures or pdf's require more memory than is installed on a original machine, you can buy additional memory modules to install on your printer which will allow you to print the entire document. I bought two 1 meg modules for about $50 each and have not had a problem since. Check your user manual or the lexmark web site to make sure that you are getting the right memory. The lexmark memory is about half the size of normal computer memory.
Dec 07, 2007 | Lexmark C510 Laser Printer
Cant load paper into my printer
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to loading the paper    . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
Please try below steps if you want to know how to load paper in to the Feeder.:
Important: When loading paper into the feeder, make sure you are using separated (i.e., cut) sheets of paper. Banner paper that is connected end-to-end should not be used unless you are specifically printing a banner.
To load separated sheets of paper:
  1. Obtain a fresh stack of paper.
  2. Separate the paper by bending it back and forth in an "S" shape before loading it into the printer.
  3. Place the paper against the right side of the sheet feeder, with the print side facing you.
  4. Gently insert the paper into the feeder. Do not  force the paper down into the printer.
  5. Squeeze the release tab and the paper guide together, and slide the paper guide to the edge of the paper.
Humid conditions may cause some sheets of paper to stick together.
If the issue still persists,  then I recommend you to look in to USER MANUAL that is provided along with Printer for instructions on loading Paper.
Well, for your convienience I'll provide you with steps that helps to access USER MANUAL.................
Steps are :
  • If the Lexmark P4300 software is already installed in Windows:
    1.  Go to Start, (All) Programs, and point to Lexmark P4300 Series.
    2.  Select User's Guide.
  • If you have not yet installed the Lexmark P4300 software, you can find the User's Guide on the installation CD.  Do the following:
    1.  Insert the CD into the CD-ROM drive. The Lexmark installation screen should appear.
      • If the screen does not appear, open My Computer and double-click on the 4300 Series icon.
    2.  Click on the ?  icon to the left of View User's Guide (including setup troubleshooting).  You will be asked whether you would prefer to save the User's Guide to the desktop and view it from there (Yes), or to view it from the CD (No).
    3.  Select the option you prefer.
  • This should resolve the issue for you.
     If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
    Bye.
    Oct 18, 2007 | Lexmark P4350 All-In-One InkJet Printer
    Computers & Internet Logo
    Top Lexmark Computers & Internet Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Robert Monigold
    Robert Monigold
    micky dee
    Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
