Question about AudioBahn AWES10P 10" Subwoofer Car Speaker
Distortion way to fast on my audiobahn awes10p
Hey there I recently bought an audiobahn awes10p subwoofer and built my own box that is around 1.5 cubic feet its 15x15x16 with a 3" port. My problem is that I have built boxes and had alot of audiobahn (alum10, alum12's, flameq) and bought this because I thought it would be a darn. I have it wired in parallel and hooked to a a2502dp audiobahn amp. My problem is how fast it distorts and how crappy it sounds. I was not impressed and i played with the port length and added an extra top plate. the port is 3" from bottom, i think tuned at 35. I am baffeled at what to do. It plays real good then i turn it louder and it just start flunkin on certain notes. thanks
    Problem Solver:
  • 22 Answers
Try to some polyphil or something like cotton to fill some of the empty space in the box to stop the echo. be sure to chek specs for the speaker you are building the box for. Speakers and their enclosures differ by speaker.
Posted on Dec 03, 2008
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
I have audiobahn amp an 3 12inch subs my amp keeps kicking into protection whats my wiring opions mono amp adnot sure what ohm the subs are
Hey sound like your amp is seeing to low of indapendece. 3 subs can be hard to wire. please give mre info on the amp and the subs? dual v/c 4ohm subs are 2ohms wired pos to pos. neg to neg.
Jan 06, 2010 | AudioBahn AW1206T Car Subwoofer
I just bought an Uudiobahn AW121T and I am trying to figure out the best and loudest box for the sub
ported pro boxes are all ways the best way to go make sure they are ported get the blk plastic ones they are the best in the pro line
Nov 17, 2009 | AudioBahn AW121T Car Subwoofer
I need the right box for my subwoofer
go to audiobahn.com and you can download your manual for your audiobahn under tech support
Apr 03, 2009 | AudioBahn AW1251 Car Subwoofer
What type of enclosure for audio bahn aw1000x
I used to be an Audiobahn dealer and can help you with the box. However I can't find specs on that model in my records or on Audiobahn's website. If you email me (dynami28@charter.net) the Theile Small parameters for the subs I can give you more exact specs. The box should be ported (Audiobahn doesn't recomend a sealded box) with about 2.5 cubic feet, made of 3/4" MDF. Here are some generic specs that should go well with that particular sub.
Air Space (Cu. Ft.) 2.4
Port Size (Inches) 4 x 6.25
Tune Freq. (Hz) 39
Mar 31, 2009 | AudioBahn AW1000X Car Subwoofer
I need wiring diagram for audiobahn AWES12P 4ohm speaker
you can go to audiobahns website. just fill in the specs like how many subs you have and what kind of amp/amps and it will give you all available wiring options.
Jan 26, 2009 | AudioBahn AW800 Car Subwoofer
Audiobahn Alum 12
did you try on screwing one?
maybe u cause a vacuum effect if you seal that box so well its a good thing .but check to see if they work oput of box 1st.if they are damage the try this spkr repair site.
http://www.mwaspeakerparts.com/
Dec 12, 2007 | AudioBahn ALUM12 Car Subwoofer
Have two alum12qa
SOUND Q SERIES
DUAL 6-OHM CONFIGURATION
Accommodating the rising trend of triple-subwoofer applications, Audiobahn’s Sound Q subwoofers come in dual 6-ohm configurations. This allows three Sound Q subwoofers to be wired in a 1- or 4-ohm operation. You now have the option to use a wider range of amplifiers to fit the needs of your specific application.
MULTI-CONNECT LUG LOCK TERMINALS
Audiobahn’s patented Multi-Connect Lug Lock Terminals offer increased versatility in wiring multiple subwoofers to an amplifier or to another voice coil. Multi-connect terminals allow you to use single wire connections in each terminal rather than combining multiple wires into one terminal. This feature allows you to use a full 8-gauge wire in each terminal.
COMMON FEATURES
Dual 6 Ohm VOICE COIL
Multi-connect Lug Lock Terminals
The Link below should answer all your questions.
Also remember to try to keep the lengths of the jumpers the same. I would make all the connections inside the box then use the teminal block of the box to connect to the amp.
Keep in mind that you can only get 1 Ohm if you use 3 woofers.
Your configuration allows for 1.5 Ohm
http://www.audiobahn.com/Audiobahn06/images/tech/wiring/parallel_parallel_dual_6.pdf
Good Luck
Apr 16, 2007 | AudioBahn ALUM12 Car Subwoofer
Car Audio & Video Logo
96 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
