Question about Teac Audio Players & Recorders
How do I transfer reel-to-reel tapes to a PC?
    Genius:
  • 1,847 Answers
You can use windows movie maker if you are using windows OS..
Posted on Dec 03, 2008
  • Legin Varghese
    Legin Varghese Dec 03, 2008
    or the best way is you use windows sound recorder
    use the mic input port to input the sound.
    If you need more assistance reply back....Kevin
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
HOW DO I PUT THE TAPE THROUGH THE REEL TO REEL
Reel-to-reel decks usually run left to right. Put full reel on left hub, take-up reel on right hub. Feed tape across read / write heads, and between pinch roller and spindle. Take end of leader tape, wind carefully around take up reel until it is secure. Press play.
Nov 30, 2015 | Audio Players & Recorders
I have a broken VHS cassette.
You can remove the 4 or 5 screws at the bottom of the tape, turn the tape over CAREFULLY pull the top off. If the tape pulled out of the end of 1 spool, you have to remove the clip in the tape hub, reinsert the tape and snap the clip back in. Holding the tape door open so as not to catch tape, put top back on and replace screws. Hope this helps.
Aug 08, 2009 | TDK T 120HS VHS Tape
I am about to begin recording reel-to-reel tapes to CD's. Should I be concerned about deteriation of tapes made in 1980
I have successfully dubbed tapes at least as old as this, probably older by a margin. If the tape plays, no problem. Just make sure that the machine heads are clean before you transfer each one.
Jun 04, 2009 | Audio Players & Recorders
The ink tape return reel won't turn to take up the used ribbon
Try to turn the wheel manually and see if it turns properly. There must be a belt or gear assembly which turns both reels simultaneously. If its a belt, check to see if its broken.
Jun 04, 2009 | Intermec EasyCoder F4 Printer
How do I thread the tape on an Akai GX210D reel to reel tape deck?
When facing the deck, the feed reel goes on the left and the take-up reel goes on the right. Make sure to secure each reel by engaging the reel locks on each of the spindles. Place the feed reel with the free end of the tape on the left and hanging downwards (like the letter "P"). Pass the tape to the right of the tension spindle (which is above and to the left of the play/record heads unit. Pull the tape down and pass it underneath the heads from left to right. Then on the right hand side of the heads unit pass the tape between the guide wheel and the first guide spindle to its left and just above. Then pass the tape over the top of the second guide spindle. Finally, loop the tape under the right hand tension spindle and pull it up and feed onto the take-up reel from the right in an anticlockwise direction (like the letter "g"). Once you have it through the slot in the centre of the reel, hold the tape end there with your finger and wind the reel around a few times to hold the tape in place and ... Voila!
Feb 19, 2009 | Audio Players & Recorders
Tape End Sensor Error - UVW1800
these error codes point to possible problems with one or both reel motors.
Dec 11, 2008 | Sony Betacam SP Small Videocassette 30...
Static cling with 3 quarter inch tape
Ngotsa, Static is NOT the reason for your fuzzy audio. Old tapes tend to deteriorate because of 1.) the way they were stored (damp, humid, and extremes in temperature), or in, or near an electric field (motor, refrigerator, TV) 2.) the lubrication (which is on all tapes) has evaporated - making good tape to head contact impossible) or 3.) the oxide (the actually tape coating) had deteriorated. As far as the Black Backing, the black backing on your newer tapes IS there to prevent static, but mainly for static build-uop during high speed rewind; if it wasn''t there, you'd actually see sparks, and you'd ocassional zaps in the sound (not overall fuzziness).
Feb 06, 2008 | Quantegy 456 Reel-To-Reel Recording Tape
Philips High Fidelity reel to reel recorder
Shot in the dark - there is an individual who does this professionally with the Philips reel to reel - may have info for you
(BTW, do not mention that I sent you - this is a secret tip)
victor@victorives.com
Dec 20, 2007 | Philips Magnavox 27MS343S 27" TV
18 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
