Question about Interlink VP4350 Mouse
Interlink 4350 wireless mouse won't work
Bought unit, installed the dongle (?) in USB port, worked fine as a mouse. Tried again a few weeks later, green light flashes on dongle, new batteries, laser works, but mouse functions won't. Tried on two computers, same result. What do I do?
You need to set a channel on the mouse and then train the USB dongle. Here's a link to the manual if you don't know or remember how to change channels and train USB dongles.
Good luck,
ObservativeTiger
Posted on Jul 17, 2012
    President:
  • 8,637 Answers
You probably already tried this.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Posted on Jan 17, 2009
How Can I connect my wireless Logitech mouse to my laptop?
You should search for small wireless USB dongle (receiver) and insert it into USB port of your laptop. You bought The dongle with mouse. Sometimes it is placed inside mouse on bottom side. See picture.
A mouse driver is usually installed automatically in a while after the dongle is connected to PC.
Logitech M310 Silver 1 Wheel USB RF Wireless Mouse Model 910 001675
Jan 18, 2016 | Logitech Cordless Mouse
Using Windows 7 - My USB logitech M-BJ58 mouse keeps disconnecting/reconnecting. It works fine on my old XP system. I've tried different USB ports, but I'll be working fine then heard the USB disconnect...
I am thinking you may have to do a system restore to before you got the update. Did you update the drivers for the mouse for Windows 7? Sometimes the older OS drivers get buggy on Win 7. You can get the drivers for free from Logitech's website. One other thing to check, make sure the USB connector is not worn, sloppy or has a broken wire under the rubber cover. It can happen. You should be able to remove the last Win update then you will know if that is the culprit. Hope that helps.
Aug 06, 2013 | Logitech M-Bj58 OPTICAL WHEEL MOUSE...
I just bought it and it won't work.
make sure the battery is good ((has full charge)) also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
hope this helps you
Nov 13, 2011 | GE Wireless Optical Mouse
I have hp mini 210 laptop. I connect usb dongle of optical mouse to laptop. It installed automatically & successfully. It showing in device manager (Human interface device) but still optical mouse is...
Welcome to FixYa!
Here's a quick checklist to resolve your wireless mouse connection.
Solution 1.
1. If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2. Make sure that the battery of the wireless mouse is placed correctly and is not drained.
3. After checking the first two steps, the optical lens on the underside of your wireless mouse should be flashing once in a while. If not, there is something wrong with the battery, the wireless mouse switch, or the wireless mouse itself is defective.
4. Connect the USB dongle in the USB port and let it install automatically.
Solution 2.
5. Connect the USB dongle in another USB port and let it install automatically.
Solution 3.
6. Restart the computer with the wireless mouse turned on and the USB dongle inserted in the computer.
Solution 4.
7. Download and install the drivers from here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=ob-47909-1
I hope that this will help.
Thank you for using FixYa and keep me posted!
Jas247
Mar 15, 2011 | HP Wireless Optical Mouse
Purchased new laptop and wireless mouse, first day worked great, after a week tried to use mouse again.....just not working have replaced battery no luck
I would try unplugging the usb receiver and restarting the computer.
Then plug it back in.
Sadly, with these, along with replacing the battery, that's the only option.
Mar 12, 2011 | HP Wireless Optical Mouse
Hello; recently bought a Logitech M305 cordless mouse. My notebook system: msi cx620mx; Windows 7 64 bit Home Premium. Mouse works normally without any problems. Exception: after hibernation / sleeping,...
Ths problem occurs because of usb drvier conflict issue with your usb wireless dongle driver. For that go to device manager uninstall all usb drivers then it will automatic install all driver. Then go to control panel->add remove program and features then uninstall your wireleless keyboard and mouse driver then reinstall. Then restart and check. Also try different usb ports of computer for connecting the usb wireless dongle of keyboard. Let me know if you need further assistance. Thanks for using FixYa.
Feb 23, 2011 | Logitech Cordless Mouse
Not responding, batteries good per the tester, dongle plugged in to USB port, was working fine for weeks months
Try testing the mouse in another computer if available to make sure the problem is not the mouse. Also try removing the usb dongle, re-boot the computer, and then re-install the usb dongle in a different usb port then the one you removed it from. This might bring the computer back recognizing the usb mouse. You could also go into the control panel(if you are using windows) and then into the device manager. Then try removing the mouse in the device manager and then re-boot the computer and see if that works.
Dec 18, 2009 | Logitech Cordless Mouse
Dell wireless mouse and keyboard-no instructions
Most Bluetooth keyboards and mice are just Plug-n-Play and does not require any driver installation. You need to isolate the problem, please follow the steps below:
1. Make sure that the wireless adapter of your wireless KB and mouse is properly connected to the USB port of the computer.
2. Make sure that the USB ports of your computer are working.
3. Use fresh batteries for the KB and mouse.
4. After connecting the wireless dongle to the computer, turn on your KB and mouse (there should be an ON/OFF switch underneath).
5. Briefly press the connect button on the wireless dongle and then hold down the connect button underneath the mouse for five seconds and then release it.
6. Do the same steps for the KB.
Have a good day!
Jun 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Microsoft Optical Wireless Mouse 3000 MSK 1056 does not work !
I fixed an MS wireless mouse that was not responding by pressing the button on the receiver while it was connected to a USB port & then pressing the button on the mouse. Worked fine after that.
Dec 23, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Optical Comfort Desktop and Mouse combo Freezing Prob.'s
have you tried pressing the connect button on the reciever then on the mouse so it picks it back up again?
May 01, 2008 | Microsoft Multimedia Optical...
Interlink VP4350 Mouse Logo
997 people viewed this question
Top Interlink Computers & Internet Experts
David Payne
David Payne
Are you an Interlink Computer and Internet Expert? Answer questions, earn points and help others
