Question about All-Pro Forced Air Kerosene Space Heater SPC-K75
All Pro heater shuts down after running for 20 minutes
I have an All Pro 110,000 BTU multi fuel heater. I checked the eye and drained the tank. If I run the heater with thecover off, it runs all day. When I put the cover back on, it runs for 20 minutes and then shuts off. Could the air stream be blowing out the flame?
  • 82 Answers
Some of these heaters have built in thermostats, check to see if your unit has one, or if it is adjustable. Also check for possible air stream restrictions causing the unit to overheat and shut off.
Posted on Dec 03, 2008
    Sergeant:
  • 204 Answers
Good Possibility. Also may want to check and see if you have an overtemp sensor somewhere.
Sincerely,
JC
It starts up good then stops and a big cloud of smoke comes out. Got a new ignighter (50$) but still doing the same. can you help me?
http://www.bealsmotor.com/manuals/113282-01.pdf You could have an air problem. Take the cover off the heater and see if it runs ok, if it does then you have an air problem, check for bad lines or cracked housings
Oct 16, 2014 | All-Pro Kerosene Garage Shop Heaters - All...
My Master 110,000 btu heater won't start after plugging it in. The tank is full of fuel. Any recommendations .
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 18, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Heater comes on fine runs 5 to 10 minutes and quits. sometimes it doesn't run that long
Are you using old fuel from last year? If so, drain/clean tank. Check/replace fuel filter. Refuel with fresh fuel & test again.
Dec 09, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a master 150000 btu kerosene direct fire heater that runs for 5 minutes then shuts down and blows white smoke. what is the problem?
The white smoke is the kerosene fuel hitting the hot combustion chamber. Your flame has went out. The cause for this could be many. The first thing you need to do is check your fuel. Remove your fuel cap and look at the bottom of the tank for trash or water. Use a good flash light. It will all settle to the bottom. If so, drain and clean out your tank. Add fresh kerosene. Check your fuel filter. Replace if dirty. Test again. If problem continues, It is possible that your photo eye could be deffective or just dirty. It is located next to the ignitor or spark plug. It sees the flame. If the flame goes out, the unit shuts down. The flame has to be smooth (not sputtering). Water in the fuel will make it sputter and the unit will shut down. When the water/moisture in tank settles to the bottom, your suction fuel line is just off the bottom which results in it picking up the water instead of good fuel. Always disgard the old fuel from previous year and start with fresh fuel. This will cut down alot of your problems in the future.
Dec 07, 2010 | Master Heaters B155DST
My reddy heater is 110,000 BTU. It started spitering and sputtering like it was out of kerosene, but still has a half a tank. Any ideas?
If you brought the heater to my shop the absolute first thing I would do is shine a flashlight into the tank. Look for water droplets (or trash) rolling around the bottom of the tank. Keep in mind if there is a "layer" of water the light won't find it. Drain the tank if there is a "hint" of contaminants.
Next, I would check the fuel filter for stoppage or restriction.
Click for more tips
Nov 23, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heater runs for 20 minutes then shuts off
These heaters have built in thermostats. Sometimes they are adjustable sometimes they are not, check to see if your is adjustable and see if this fixes your problem. Also check to see if there is any air restrictions possibly causing the heater to over heat.
Dec 03, 2008 | All-Pro Forced Air Kerosene Space Heater...
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
All pro multi fuel
This may sound dumb, but is it full? i have a simupar one and if i start it out at 1/4 tank or ness it will not run long before it shuts off.
Dec 12, 2007 | All-Pro Forced Air Kerosene Space Heater...
All-Pro Forced Air Kerosene Space Heater SPC-K75 Logo
46 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
