Question about HP Compaq FP 7317 17" Flat Panel LCD Monitor
How do I disassemble the unit and repair or trouble shoot? Got two of em and both doing the exact same thing? Only two and a half years old!!!!
  • 537 Answers
If they are still under warranty, contact HP. If not, it may not be worth repairing. Sometimes a leaky power capacitor can be fixed. Otherwise the other components are surface mount and are very tricky to diagnose/repair.
Posted on Dec 03, 2008
My hp ml370 g4 startup and the health led is green but when the dignostic utility appers on screen the health led become red and the keyboard not responding help plzzzzzzzzzzzzz
Open the case and turn on. There should be a corresponding led lit inside. That, or you could run Insight Manager. It will tell you exact details.
Feb 28, 2013 | HP ProLiant ML370 G4 Server
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
I had to get a new screen because my LED shattered. The person who replaced the screen missed connecting/wiring that green lit up strip that turns on/off Wi Fi, controls volume, etc. Its for a HP EliteBook...
Unfortunately, the only way to solve your problem is to take the laptop back apart and re-connect the wires, and _hope_ that the reason why they didn't get re-connected in the first place wasn't because they were broken when it was disassembled.
Laptop repair is not difficult as long as you _carefully_ follow all the instructions, be very careful how you disconnect the cables, and, probably the hardest part is keeping track of the screws. One way to keep track of the screws is to use an egg carton and write on the carton where the screws came from.
Take pictures before disassembly if you have too.
Here's the HP webpage that tells you in detail how to disassemble and re-assemble your laptop:
Sep 11, 2010 | HP Elitebook 8530w Mobile Notebook
Monitor will come on, monitor status box will come on and then screen goes blank. How can I fix this?
rwhite97, If your pc is working fine with substitute monitor, and w1907 lcd unit does same (black screen, or blanknblack screen) when connected to a "known good" pc, then you should visit and read some stuff at this 2005 blog. Then learn the flashlight test and what it means. Then go to YOUTUBE for video clips on lcd monitor disassembly and lcd monitor repair if you are into do-it-yourself repair. Remember this!!! Your w1907 unit uses the same basic design and operation principles that ALL brands of ccfl back-lit lcd monitors use. Good luck with the repair. Come back here and leave comment after doing your research/investigation and then rate this response. 12fixlouie
Jul 16, 2010 | HP w1907 LCD Monitor
Aficio 2035 S/P: toner leak
Four things to look for here.....
1. Did you remove the inner top of the toner bottle? The clear one. That will create a mess. Only remove the black cap.
2. The seal between the toner hopper and the top of the photoconductor unit has been damaged. Need to replace or fix this. You can see the seal around the hole in the pcu when you pull the toner hopper out.
3. The claws in the toner hopper that grab the top of the toner bottle are bound up or the release mechanism (green handle area) is messed up. Clean if you can or replace worn parts.
4. If the copies are getting light, then the plastic 'scoopers' inside of the toner hopper are damaged. You will need to disassemble the receptacle the toner bottle fits into and repair the 'scoopers'. If they are still there, just glue them back on.
Sep 15, 2009 | Ricoh Aficio 1018D Copier
ASUS P4XP-X won't energized after minimal repair
Either the board was damaged during the repair attempt, or was bad to begin with. The original problem description (black screen) sounds like typical mobo "no boot" trouble. The loose heatsink on the chip may have contributed to the failure, or it may have been simply coincidence. Given the low cost of motherboards, it's silly to spend any more time on attempting to diagnose and repair a problem. Just replace the board and move on.
May 10, 2009 | Computers & Internet
I re-started my toshiba A135 laptop, and the screen went black
There are dozens of possible root causes for your problem I guess.
But exactly the same happened to me in fact on a packard bell laptop. After my son forced it to reset, it didn't start again. Only one led was lit. After a long search I found that the battery had died and this prevented the laptop to start even when the power supply was plugged in.
Try this: remove the battery, connect it to the power supply and restart.
Hope that helps
Jan 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Follow up questions
Normal sequence is the power led should blink 5 times then shutoff when power is pressed. If the led stays lit the DM is suspect. You will need to have the DM trouble shooted to determine whats preventing normal boot sequence from completeing. If you need further assistance. please let me know.
Your chassis is the ATC322
Jul 07, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
Black screen and no sound
I had the exact same problem with my Magnavox TV. No sound and no video but the power light was lit. I finaly gave up on finding a solution on the web and called in a repair tech. He fixed my TV in less than 30 minutes. You can find the solution here.
Jun 16, 2008 | Philips Magnavox 9P6034C 60" Rear...
Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
HP Compaq FP 7317 17" Flat Panel LCD Monitor Logo
441 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
