Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Xbox 360 Console Not Reading Discs
By cronkerz4 on Dec 03, 2008
Hey, when I insert one of my Xbox 360 Games, it says "Reading..." then 5 seconds later it says "Open Tray.." I don't know what to do with my Xbox System.
Same Problem
May 25, 2009
-   this one game is not working for my xbox 360 but, the same disk works on my friends xbox 360 and all my other games work on my xbox 360, some times they wont read the disk some times it does. i need help -   vex795
Apr 30, 2009
-   when i put the game in the disc drive close it its says"reading" makes two funny noises, spins the disc for a second and returns the the "open tray" scene. -   milman87
Apr 30, 2009
-   will not read any disks at all, asys reading the about 10 seconds later it sas oen tray.-   jeff glide
Mar 09, 2009
-   doesnt recognize it self as an Xbox 360 console
its starting to upset me.
-   Guest
Jan 27, 2009
-   I have the same issue and xbox support just said my console is 3 months out of warranty and it will require $99 bucks for them to fix, the upside is that they will put another one year warranty on the machine. I am so PO I cant see straight and so ticked about my 3rd Xbox going down.-   Guest
Solution #1
posted on Jan 09, 2009
Somewhat Helpful)
richard777
Rank: Master
Rating: 78%, 18 votes
you might check out the informative blog post at Xbox 360 Disc Read Error Fix
Hope it helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 11, 2009
Not Rated)
XboxRepKit
Rank: Guru  Microsoft Expert
Rating: 93%, 30 votes
this could mean your laser is on its way out, but it could also mean it needs cleaning. the best way to
clean is to strip the machine down. strip the dvd drive down and get a cotton earbud.
spit on the earbud and very gently wipe the laser eye clockwise but dont press on too hard, very gently.
also get a clean paintbrush and give the drive casings a good clean.
this might help. there is also something else you can try and thats something called asjusting the 'pots',
this is a bit complicated for anyone not used to the process but i do have a guide if you want to have a
go yourself. what this does is adjust the laser power so its a full again just like it was when you first
bought it. (thats the easy explanation).
regards
linda
Was this helpful?
Yes
No
Solution #3
posted on Nov 10, 2009
Not Rated)
yourhelp
Rank: Wiz  Video Games  Expert
Rating: 82%, 77 votes
If you have the disc reading error it is caused by the receptors on the back of the Xbox 360 overheating.
You need to get this fixed, you can do this by fixing it yourself or sending it in.
Was this helpful?
Yes
No
Solution #4
Not Rated)
Nickpick123
Rank: Apprentice  Video Games  Expert
Rating: 40%, 1 votes
Just turn it on its side! I did it and it started working again! ;D
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
xbox has 4 red rings, freezes
Answer
when puting new games, the game won't load only reads play dvd and then shows a huge xbox 360 logo.... (More)
Answer
what can i do to fix my xbox 360 with 2 red ring. i already took apart and cleaned an the fans are... (More)
Answer
my xbox is having the invalid format problem...happened while playing, the colors went weird so i... (More)
Answer
It says my xbox connection is not working. How do I fix this
27 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 27, 2009
dang my 360 wont read any of my 360 game...any idea
Comment by Guest, posted on Jan 26, 2009
omg same problem i hate this..
Comment by jimmydean894, posted on Jan 26, 2009
i load a dics, in a few of seconds, comes on open tray
Comment by rudeboi_ess, posted on Jan 24, 2009
yeh mines only 10 months old, keeps sayin open tray please let me no if a solutions found.
Comment by jojo4todd, posted on Jan 24, 2009
i have the same problem, except it is not reading any of my discs!
Comment by lawlstev, posted on Jan 24, 2009
I have the same problem as you all too. I notice that this problem seems to of only happened with us all after the new dashboard came to town. Does any think there is a link?
Comment by kronicmuffin, posted on Jan 20, 2009
i have that same problem and some times it says that my games are dvd
Comment by Guest, posted on Jan 20, 2009
Same here, I can usually get it to work by blowing some can air into disk slot. No clue why that helps, just thinking the head may have dust,etc. on it. Not a long term solution though, because it keeps doing it.
Comment by Guest, posted on Jan 15, 2009
I got the same problem if u find out how to fix it hit my e-mail bigdog1672001@yahoo.com
Comment by Guest, posted on Jan 11, 2009
not reading disks
Comment by worcester13, posted on Jan 05, 2009
No matter how many times I keep trying different disks it comes up with the exact same problem. Reading then Open tray. Please someone help
Comment by rpsizemore, posted on Jan 05, 2009
i have that same problem to and i dont know why my xbox wont read the disk but sometimes when i get lucky it will read the disk its like something is loose in my xbox 360. when i get lucky and my xbox reads the disk it makes little clicky noises like something is loose.
Comment by Guest, posted on Jan 05, 2009
reading then open tray
Comment by anitafrost, posted on Jan 01, 2009
Far Cry won't work
My 360 will load all of my other games and I am able to play them except for Far Cry 2. I put the disk in and it says reading for a short time period, but won't start the game.
Comment by ben_regino92, posted on Jan 01, 2009
My xbox wont read the dics it will say reading then stop then it will say open tray, it worked a little while after then when i turned it off and a little later turned it back on it does it again
Comment by billsled75, posted on Dec 31, 2008
same thing with mine. i think i watched something on youtube that said that you need to replace the dvd drive maybe.
Comment by chanstag, posted on Dec 31, 2008
I am having the very same problem with my xbox 360. It will act as if it is reading the disk and just go to "Open Tray". anyone out there now of a fix or where to get one fixed without sending back to microsoft?
Comment by Guest, posted on Dec 31, 2008
effing a. me too. and no one knows what to do about it. someone help!
Comment by Guest, posted on Dec 28, 2008
360 makes a funny sound says reading then couple seconds later it says open tray
Comment by Guest, posted on Dec 03, 2008
i hate it me too
Comment by blue12121, posted on Dec 03, 2008
This started with Far Cry 2. I put the disc in and close the tray. It says its reading, makes some funny noises and then says open tray. If i go through this process for half an hour to an hour it eventually works. It plays some games fine(Guitar Hero 3) but has the same problem with some dvds. It played Wanted fine but didnt like Step Brothers. Whats the deal?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Xbox 360 Console:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 756
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
