Question about Refrigerators
Condensor sounds like it moans for a couple of seconds instead
The frig does not sound like it is running correctly, it sounds like the condensor moans for a couple of seconds, everything is cooling correctly but I wonder if it about to go out
  • Walter Whitaker
    Walter Whitaker May 11, 2010
    Did you mean the compressor?
    Scholar:
  • 82 Answers
Hello aeruslady1,
Do you mean the compressor? I'm sure you do. The condenser is the hot refrigerant line that comes off of the compressor.
It just sounds like you have an old compressor. I have seen them make noises for years before they take a dump. If it continues to run loud even after it starts however, then you may need to clean the condenser coil or replace the condenser fan motor. Another thing that might make it run loud is some refrigerant lines may be rubbing against something. This can be remedied by bending the lines.
Hopefully this helps.
Sincerely,
shays5415
Posted on Dec 03, 2008
GE side by side frig, Moans and groans fan seems to be hunting for a constant speed.
its your evap. fan motor or condensor fan motor. bearings are prob. going out
Nov 04, 2009 | Heating & Cooling
My Amana refrigerator with bottom freezer thaws intermittently, every 5 days or so. When it thaws there is a buzzing sound from the fridge that lasts a couple of seconds and recurs every 30-60 seconds....
The techs are correct. The sound you hear is the compressor trying to start.
Most appliance parts companies sell what is called a
start kit or hard start kit. I personally use the "ic13".
It has given me the best results but it's a **** shoot.
If you feel like gambling, try it. As well,
It is very important that you run the machine with the back cover in place. It ducts the air to the condenser . Very important. Make sure the condensor coils are clean, as well.
Oct 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
KitchenAid KSBS20QEWH0 side by side front of box is very warm to touch. No sound from condensor fan. Inside frig and freezer are cold. Seems like compressor is running constantly.
The condenser fan is probably the problem. Take the cardboard cover off the back to see it and test it. How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 25, 2009 | Refrigerators
Condenser shuts down after a couple of hours.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
Aug 19, 2009 | Amana Haier AP125HD Air Conditioner
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
My check light keeps coming on my dometic ref in my 5th wheel
I have had this problem also. My experience has been that the propane line to the frig has air in it, especially after not being used for a while. Here's what I do:
1) Make sure the propane tank valve is open.
2) Light one of the burners on the stove. This may take a while but keep the gas on and a lighter at the burner. This is safe becuase as the air purges from the line it just blows the flame (from the ligher) around. Then when the air is purged the gas lights. Let the burner run for a couple of minutes. This sounds a bit odd, but what you are doing is bringing the "gas" close to the frig. The frig does not have to purge all that air as you have already done most of the purging by getting the burner to light. The facory setting for the frig is to stop trying to light after 45 seconds, and the "Check" light comes on.
3) Now try the frig. It may a couple times, but it should light and work fine.
I have found that this technique also helps with lighting the hot water.
Apr 05, 2009 | Refrigerators
Our fridge/freezer is making a moaning sound. we
if the timer is making clock sound is the timer may be you have a fan making noise
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Gold Conquest light is flashing and clicking sound
With sounds like that I would use caution if installing a light bulb there. The sound and description sounds like a short circuit. Did this happen recently? Could you get me the complete model number, for example GS6SHEXN
Let me know, Thanks Sea Breeze
Mar 14, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Moaning noise in steering column
The probably lubed the intermediat shaft conenction. The loud poping noise could be from them not sitting the boot back correctly. Inspect your boot. As for the moaning noise Only thing I can think of is a hydraulic noise.
Dec 11, 2008 | 2007 Saturn Outlook
Refrigerators Logo
185 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
