Question about Jabra BT250 Consumer Headset
I cannot hear with my Jabra BT250 headset
I have one Jabra BT250 paired with Nokia E62 and I cannot hear anything with phone. Everybody can listen my voice, but I cannot listen their voices.
4 Suggested Answers
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
SOURCE: Cannot pair a7010 with Plantronics Voyager 520
The actual problem was Plantronics, I was not turning on pairing mode. I was confused with quick pair which starts not immediately after turning on, but you need to hold the button longer until led will start blinking blue and red.
Posted on Aug 23, 2008
SOURCE: I have lost instructions from my Jabra BT250 and
switch off jabra. Hold down on/off button for sabout 10 secs until blue light is continuously on. Then pair from the phone. Pin 0000
Posted on Sep 07, 2009
  • 4 Answers
SOURCE: my jabra headset won't pair with my phone--my
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Posted on Dec 16, 2009
Testimonial: "This worked perfectly! Thanks!"
0 characters
1 Points
How do i pair my jabra bt250 to my htc desire hd
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
Hi, i have just set my JABRA BT 2070 however i accidently clicked on LETS FORGET this and now my jabra bt2070 is not pairing ny longer, please help
1. Switch Bluetooth headset off. 2. Press and hold the answer/end button until a solid blue light comes on. Headset in pairing mode. 3. Go into phone's bluetooth options and "search/look" for devices. you should see the headset. 4.Pass code is "0000"
should connect and be good :)
hope this helps
Apr 17, 2011 | Jabra BT250 Consumer Headset
Connecting cell phone and Jabra
Check that both devices are BT enabled and in pairing mode -ie, leds blinking-. If one of the device is not in pairing mode, it is normal that the process fails.
If you experience the same problem on other phones with your Jabra BCE-250 -same as mine-, you might think of getting it checked first.
Dec 10, 2009 | Jabra BT250 Consumer Headset
Jabra OTE1 pairing problem
Every time i turned my jabra on the three beeps are in slow motion why?
Aug 15, 2009 | Jabra BT250 Consumer Headset
I have lost instructions from my Jabra BT250 and can't remember how to pair? my new phone is a htc
Jul 05, 2009 | Jabra BT250 Consumer Headset
JABRA BT250V Hearing Problem
Cannot get my Jabra BT 250v to work with my Blackberry Curve 8310. Phone indicates I am paired, but there is no audio through earpiece. You can still hear audio through phone. Help.
Jun 18, 2008 | Jabra BT250 Consumer Headset
Jabra bce-250
how to connact nokia 6300 with jabra bce-205 wireless headset
Nov 27, 2007 | Jabra BT250 Consumer Headset
Connection was ok , then device stopped being found by phone when both were fully charged.
you will need to go into the phones bluetooth devices and delete the Jabra headset and then pair it up again.
Oct 12, 2007 | Jabra BT250 Consumer Headset
Pairing with a phone
this happened to me too.. i googled a user manual for it.. if i recall it said, turn the headset power off, then once the phone is in pairing mode, hold the power button on the headset till the light stops blinking and becomes a solid blue light. then the headset is in pairing mode as well and your phone should find it
Mar 20, 2007 | Jabra BT250 Consumer Headset
Jabra BT250 Consumer Headset Logo
88 people viewed this question
Top Jabra Headsets Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Richard Schabler
Are you a Jabra Headset Expert? Answer questions, earn points and help others
