Question about Dryers
I need a wiring schematic for a speed queen heavy duty gas dryer m#FG6041W S# 53H35568
    Genius:
  • 1,847 Answers
May i have the make of this dryer?
Posted on Dec 03, 2008
    Sergeant:
    Champion:
  • 393 Answers
Remove the covers there should be a schematic somewhere near the motor/on one of panels
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
I have a GAS Speed Queen clothes dryer. I can't locate the model number. It says "Heavy Duty, Multi Cycle, All Fabric Automatic Dryer". I bought it new in September 1972. It has always...
It could be the vent chambers in the bottom of the machine from the front filter to the vent output to the rear exit vent ducting tubes....or the ducting itself. Flexable ducting, if you are using it, are well known to glog due to the multiple ringed wires inside. Flex is not recommended.
Also the gas line should be replaced with a gas flex line....it's the law here in CA.
Jun 26, 2011 | Speed Queen ADG4BR Dryer
I have a Speed Queen Heavy Duty Large capacity wash machine model:AWM 351-3062 I need to find out ifit has a steel drum
Yes, all Speed Queens have a stainless steel tub, some are coated, but underneath is stainless steel
Jun 12, 2010 | Washing Machines
I have a Mcgraw-Edison speed queen Heavy Duty dryer. We used it last night and it worked fine except there was alot of condensation inside the dryer with a little water coming out the door. Now this...
You may have a venting problem. Check outside to make sure vent is blowing good. It is possible that the motor may have went bad with all of the problems associated with a clogged vent.
Dec 02, 2009 | Speed Queen AES28AWF Electric Dryer
I have a speed queen gas dryer. do i have to
It would be safest to turn off the gas supply. You should have a gas **** in line for this purpose.
Aug 29, 2009 | Speed Queen Dryers
WASHER VERY LOUD AFTER I REPLACED DIRECT DRIVE PUMP
No... I work speed queen all day long and I know they can be loud. Just double check and make sure the washer is sitting level. But other than that speed queen washers and dryers are just very heavy duty work horses.
Apr 08, 2009 | Washing Machines
Where do you find the thermostat or the fuse on dryer?
Unplug the dryer.
Remove the front panel. Two screws on the bottom left and right about 3 inches from the floor and 3 inches in from the sides.
Lift the panel off.
Remove the 2 screws on the bottom right and left of the door. Pull forward and raise it up to disengage lock tabs. Remove the door switch wires.
Under the top lid you will see 2 screws right and left holding the top on. Remove these and lift the top to the rear of the dryer.
From the floor position, reach in and remove the drum belt from the pulley and tension roller.
Remove the drum from the dryer.
On the bottom left rear of the inside cabinet you will see the heater,fuses and thermostats.
With a volt/ohm meter (vom) set for continuity you can remove at least one wire from each part. Then check for continuity through each part.
If you get no reading the part is bad.
Look for burned/separated wires also.
Reverse the above order to re-install parts.
Good luck.
Nov 30, 2008 | Speed Queen AES28AWF Electric Dryer
Marathon Compucare Dryer
Could be a touchpad problem
Dec 09, 2017 | Dryers
Dryers Logo
29 people viewed this question
Top Dryers Experts
