Question about Maytag Performa PAV2200
Agitator noise in maytag performa machine
POssible cause and remidies?
The noise in your washer tub could be caused by some object lodged under the agetator. Lift off agetator and check. Or somthing could have gotten into the sump tub. this could be a major job as you would have to remove the complete inner tub assy. One other problem I can think of it could be worn tub bearings. If the washer is 10 or 15 years old I would replace it,
ljtomega
Posted on Dec 03, 2008
My maytag performa pav 2300 is making a loud noise while its spinning. Sounds like metal on metal. Its working fine. Its just that noise. We just got a new motor yesterday. What could be the problem ?...
Hello
On this model washer the noise is most likely caused by a worn washer tub seal assembly. remove agitator (nut on the top under cap), spin basket and tub assembly. remove seal and install new one.
Nov 03, 2011 | Maytag Performa PAV2200
Maytag performa making LOUD squeeling noise when agitating and spinning
Most likely the tub bearing has gone bad on your washer.
Apr 07, 2011 | Maytag Performa PAV2200
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Performa PAV2200 makes a rumbling sound while agetating. Suspect a worn bearing or belt? Could you shed any light on this?
Yes it could be the spin bearing at the base on top of the brake assembly. I would suspect that the brake assembly is the cause of the noise as this engaged when you the washer agitates. If it was the bearing it would make a loud noise in the spin cycle, too.
Nov 05, 2009 | Maytag Performa PAV2200
Maytag Performa PAVT920AWW washer makes a squealing sound
i am sorry but i had this problem happen before with my customer maytag performa, what i found out is that the brakes become crystallized, causeing a squeaking noise, remember in agitation, the brakes stops the the drum from spinning, what i advise you to do is change out the breaks or take the brake pads and rub them with sand paper
thanks
Aug 23, 2009 | Washing Machines
Maytag Performa top loader is making grinding noises
The agitators are a pop-on fit. Make sure that the agitator is firmly seated on the shaft. Lift it up and if it moves easily adjust it to the splines on the shaft and press it back into place.
Jul 29, 2009 | Maytag Performa PAV3200
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Jul 27, 2009 | Maytag Performa PAV3200
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
Washing Machines Logo
209 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
